How do I simply pull and run hello-world?
nicholas@mordor:~$
nicholas@mordor:~$
nicholas@mordor:~$ snap list docker
Name    Version   Rev   Tracking       Publisher   Notes
docker  20.10.14  1779  latest/stable  canonical✓  -
nicholas@mordor:~$
nicholas@mordor:~$ sudo docker pull hello-world
Using default tag: latest
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
nicholas@mordor:~$
nicholas@mordor:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 22.04 LTS
Release:    22.04
Codename:   jammy
nicholas@mordor:~$
nicholas@mordor:~$ sudo systemctl start docker
Failed to start docker.service: Unit docker.service not found.
nicholas@mordor:~$
nicholas@mordor:~$ sudo systemctl status docker
Unit docker.service could not be found.
nicholas@mordor:~$
see also:
https://stackoverflow.com/questions/44678725/cannot-connect-to-the-docker-daemon-at-unix-var-run-docker-sock-is-the-docker
In my case, to remedy the "Unit docker.service could not be found" issue, I needed to run...
sudo apt-get install docker-ce docker-ce-cli containerd.io docker-compose-plugin
(Source: https://docs.docker.com/engine/install/ubuntu/)
For my case, after install Docker Desktop from .deb file, I ran
after that, I tried to run the service
and it works! Peviously after I ran sudo apt --fix-broken install when failed to install docker .deb file, it didn't mention the docker-ce is needed. And found out that docker-ce is needed later.
Yodi S.
  • 31
It might be that the snap version of docker is just the docker client, and not the actual docker daemon and service. I recommend going to their site and trying to install it using their instructions as it'll likely have the full package
Instructions here for Ubuntu
This option helped me: 1.
for pkg in docker.io docker-doc docker-compose docker-compose-v2 podman-docker containerd runc;
do
  sudo apt-get remove $pkg;
done
sudo apt-get update
sudo apt-get install ca-certificates curl
sudo install -m 0755 -d /etc/apt/keyrings
sudo curl -fsSL https://download.docker.com/linux/ubuntu/gpg -o /etc/apt/keyrings/docker.asc
sudo chmod a+r /etc/apt/keyrings/docker.asc
echo
"deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.asc] https://download.docker.com/linux/ubuntu
$(. /etc/os-release && echo "$VERSION_CODENAME") stable" |
sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
sudo apt-get update
sudo apt-get install docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin
BCS
  • 103
