I have this issue.
Install VMWare Player on Ubuntu 22.04 (kernel 5.17)
And I followed the answer provided. On the last command:
sudo vmware-modconfig --console --install-all
It fails with this:
[AppLoader] GLib does not have GSettings support. Segmentation fault
I find many repeats of this in the VMWare logs if I try to start VMWare Player and it tried to compile the modules into the Kernel:
2022-09-24T02:09:02.435Z In(05) host-5139 /tmp/modconfig-1tm6gJ/vmmon-only/./include/vm_asm_x86.h:67:44: error: expression in static assertion is not constant
2022-09-24T02:09:02.435Z In(05) host-5139    67 |    ASSERT_ON_COMPILE(sizeof(Selector) == 2 &&                                \
2022-09-24T02:09:02.435Z In(05) host-5139       |                      ~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2022-09-24T02:09:02.435Z In(05) host-5139    68 |                      ((__builtin_constant_p(expr) && ((expr) >> 16) == 0) || \
2022-09-24T02:09:02.435Z In(05) host-5139       |                      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2022-09-24T02:09:02.435Z In(05) host-5139    69 |                       sizeof(expr) <= 2))
2022-09-24T02:09:02.435Z In(05) host-5139 /tmp/modconfig-1tm6gJ/vmmon-only/./include/vm_assert.h:372:22: note: in definition of macro ‘ASSERT_ON_COMPILE’
2022-09-24T02:09:02.435Z In(05) host-5139   372 |       _Static_assert(e, #e); \
2022-09-24T02:09:02.435Z In(05) host-5139       |                      ^
2022-09-24T02:09:02.435Z In(05) host-5139 /tmp/modconfig-1tm6gJ/vmmon-only/./include/vm_asm_x86.h:263:7: note: in expansion of macro ‘ASSERT_ON_COMPILE_SELECTOR_SIZE’
2022-09-24T02:09:02.435Z In(05) host-5139   263 |       ASSERT_ON_COMPILE_SELECTOR_SIZE(expr);                            \
2022-09-24T02:09:02.435Z In(05) host-5139       |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2022-09-24T02:09:02.435Z In(05) host-5139 /tmp/modconfig-1tm6gJ/vmmon-only/common/task.c:726:7: note: in expansion of macro ‘SET_TR’
2022-09-24T02:09:02.435Z In(05) host-5139   726 |       SET_TR(tr);
What do I need to do?
JMorgan
Great question - I might have the solution you are looking for. Per this video: https://www.youtube.com/watch?v=bYAdPOSxh8c, you should try running these commands in sequence, and it will resolve the issue.
sudo apt install libaio1
sudo apt install build-essential
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt install gcc9
Rerun the sudo vmware-modconfig --console --install-all command, and enjoy!
