I'm on Kubuntu 22.04 with a kernel version of 5.19.0-32-generic (verified with the command uname -a)
I have downloaded VMWare Player 17.0.2 and installed it without problems but when I try to run it I got this error : Message Box
I have already try to add synlinks with :
cd /lib/modules/$(uname -r)/build/include/linux
sudo ln -s ../generated/utsrelease.h
sudo ln -s ../generated/autoconf.h
sudo ln -s ../generated/uapi/linux/version.h
and put the path with /usr/src/linux-headers-5.19.0-32-generic/include but it doesn't work and I got this message : Message Box
I have already verified that I got the last kernel headers with :
sudo apt-get install build-essential
sudo apt-get install linux-headers-$(uname -r)
Finally I tried this command : sudo vmware-modconfig --console --install-all and got this error :
[AppLoader] GLib does not have GSettings support.
(process:15928): GLib-CRITICAL **: 22:33:39.910: g_file_test: assertion 'filename != NULL' failed Failed to setup build environment.
Do you have any ideas of how to solve this problem and run VMWare (if possible without recompiling old kernel modules), thanks.
