I wanted to try libreoffice 7, however, the application crashes and it does not open even after running safe mode and restoring the profile This solution I found here.
I am using kubuntu focal fossa.
I want to go back to the previous version, libreoffice 6. I have tried the following solution:
sudo apt-get install ppa-purge && sudo ppa-purge ppa:libreoffice/ppa
But it gave me the following warning:
"PPA to be removed: ppa:libreoffice ppa:libreoffice
Warning: Could not find package list for PPA: ppa:libreoffice ppa:libreoffice"
Can someone help me, please?
norbekoff
  • 107
Using Ubuntu Software, remove LibreOffice.
Then open "Software & Updates". On the second tab, "Other Software", uncheck the checkmark before both libreoffice PPA's (https://ppa.launchpadcontent.net/libreoffice/ppa/ubuntu..., one with binary code and one with source code). This inactivates the PPA. You can also fully remove by selecting the PPA and clicking "Remove"
Hit "Close" to close "Software & Updates". This will automatically refresh the software lists.
Reinstall LibreOffice from Ubuntu Software. Make sure you select the older .deb version and not the recent snap version.
vanadium
  • 97,564
