-1
I just got Unity3D working on my laptop, and celebrated by trying out some of the new features that weren't available to me in Unity2D.
While I was playing around with the settings for Desktop Cube and Rotate Cube, the desktop froze and I had to do a hard reboot (holding the on/off-button on my computer until it shut of, then turn it on again). Now, when I try to boot into Ubuntu, the system freezes and I can't get in.
I tried removing quiet and changing splash to no-splash in the grub boot script, but I didn't get any useful information because the "freezing point" was just after the Ubuntu logo and mouse shows up (I assume right after the X-server starts...?)
I've set up my computer to log me in automatically from boot, so I can't (easily) get to the login screen either, to choose "Ubuntu 2D" and login and change the failing settings (whatever they are). I can drop to root shell from boot - however, once in the root shell, I have no idea what to do to fix this problem
Tomas Aschan
  • 2,952
I tried various ways to reset the settings from a root shell, including the following:
  1. compiz --reset
  2. unity --reset
  3. gconftool --recursive-unset /apps/compiz-1
  4. Either of the above, preceded by su tomas
However, none of it worked. I ended up reinstalling Ubuntu 12.04 without formatting any partitions (and making sure to select the same mount points as the ones I had before all of this happened). The installation took less than 20 minutes and could restore most of the stuff that I had from before.
Tomas Aschan
  • 2,952
If you can open terminal then run gconftool-2 --recursive-unset /apps/compiz && gconftool-2 --recursive-unset /apps/compiz-1. Then restart.
or
1.Boot into live cd
goto /home/ directory in the partition where you have installed ubuntu.
2.remove
~/.gconf/apps/compiz-1
~/.gconf/apps/compizconfig-1
~/.gconf/apps/metacity
~/.config/compiz-1
you must delete this folder from your home directory not home directory of your current live session.
Rahul Virpara
  • 11,860
