All of a sudden (or so it seems), the LibreOffice modules won't start. All I get is the LibreOffice community banner for a second and then nothing. It has been working just fine up until today and I have no idea what changed. The version is
LibreOffice 7.3.6.2 30(Build:2)
This is what happens if I run it from the command prompt:
$ libreoffice
terminate called after throwing an instance of 'com::sun::star::deployment::DeploymentException'
Unspecified Application Error
John Birberg
  • 23
Make sure you have libraoffice-gtk3 installed as this is a dependency and does throw those error messages.
sudo apt install libreoffice-gtk3
Let us know if you have sorted it out.
You may have an extension installed for the user locally, while the same extension was installed in the system in the meantime. Try removing the LibreOffice profile folders at ~/.libreoffice and ~/.config/libreoffice.
Jack
  • 16
