Your processor, i7-4700MQ, predates HWP (HardWare Pstate) control. The migration path as determined by the kernel power management group, for these Intel processors is to default towards the intel_pstate CPU frequency scaling driver being in passive mode using the schedutil scaling governor. To that end this commit was done:
commit 33aa46f252c703e42c81a76696cd0c240f2281e4 Author: Rafael J.
Wysocki rafael.j.wysocki@intel.com Date: Wed Mar 25 15:03:35 2020
+0100
cpufreq: intel_pstate: Use passive mode by default without HWP
After recent changes allowing scale-invariant utilization to be
used on x86, the schedutil governor on top of intel_pstate in the
passive mode should be on par with (or better than) the active mode
"powersave" algorithm of intel_pstate on systems in which
hardware-managed P-states (HWP) are not used, so it should not be
necessary to use the internal scaling algorithm in those cases.
Accordingly, modify intel_pstate to start in the passive mode by
default if the processor at hand does not support HWP of if the driver
is requested to avoid using HWP through the kernel command line.
Among other things, that will allow utilization clamps and the
support for RT/DL tasks in the schedutil governor to be utilized on
systems in which intel_pstate is used.
You are actually using the intel_pstate CPU frequency scaling driver, however it is in passive mode. Try this:
echo active | sudo tee /sys/devices/system/cpu/intel_pstate/status
and then check:
cat /sys/devices/system/cpu/intel_pstate/status
If that works as expected then change your grub line to:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_pstate=active"
and see if it boots the way you want.
Note that the CPU Frequency scaling driver intel_cpufreq is just the intel_pstate driver in passive mode.
Example:
doug@s19:~/temp$ grep . /sys/devices/system/cpu/cpu*/cpufreq/scaling_driver
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu10/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu11/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu1/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu2/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu3/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu4/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu5/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu6/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu7/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu8/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu9/cpufreq/scaling_driver:intel_cpufreq
doug@s19:~/temp$ cat /sys/devices/system/cpu/intel_pstate/status
passive
doug@s19:~/temp$ echo active | sudo tee /sys/devices/system/cpu/intel_pstate/status
active
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu10/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu11/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu1/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu2/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu3/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu4/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu5/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu6/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu7/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu8/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu9/cpufreq/scaling_driver:intel_pstate
