Using 22.04 and my default input device gets reset at every reboot. Looks like the settings from 'Sound' menu are not being saved - this is from a 'fresh' Ubuntu 22.04.1 install.
Is this the only way to sort it out? If yes - why is the UI non-functional?
Thanks?
I executed:
pactl list short sources
and then
pactl set-default-source alsa_input.pci-0000_10_00.4.analog-stereo
hopefully this should work but basic expectation is for the UI to be fully functional...
This solution doesn't even work. Disappointing.
Emanuele
  • 1,044
The command you listed worked for me. Here's what I input / output:
2   alsa_output.usb-Blue_Microphones_Yeti_Stereo_Microphone_REV8-00.analog-stereo.monitor   module-alsa-card.c  s16le 2ch 44100Hz   SUSPENDED
3   alsa_input.usb-Blue_Microphones_Yeti_Stereo_Microphone_REV8-00.analog-stereo    module-alsa-card.c  s16le 2ch 44100Hz   SUSPENDED
5   alsa_input.usb-046d_HD_Pro_Webcam_C920_E829CA2F-02.analog-stereo    module-alsa-card.c  s16le 2ch 32000Hz   SUSPENDED
6   alsa_output.usb-Logitech_PRO_X_Wireless_Gaming_Headset-00.analog-stereo.monitor module-alsa-card.c  s16le 2ch 48000Hz   IDLE
7   alsa_input.usb-Logitech_PRO_X_Wireless_Gaming_Headset-00.mono-fallback  module-alsa-card.c  s16le 1ch 44100Hz   IDLE
8   alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor module-alsa-card.c  s16le 2ch 44100Hz   SUSPENDED
And I ran:
pactl set-default-source alsa_output.usb-Logitech_PRO_X_Wireless_Gaming_Headset-00.analog-stereo.monitor and it worked
