I have a Raspberry Pi running Ubuntu 21.10, which I recently learned is EOL. No worries, I'll just upgrade to the next version (which, happily enough, is an LTS release)... or so I thought...
I'd like to upgrade to Ubuntu 22.04 LTS, but none of the upgrade tools seem to be working at all, which is very confusing to me.
For context, I'm accustomed to working with Debian, where you simply edit your apt.sources.list and upgrade packages. From what I've found, with Ubuntu, the preferred method of upgrading seems to be the do-release-upgrade tool. However, that tool is not doing anything on my system (and I haven't found any command-line switches like --actually-do-upgrade that I'm missing):
anthony@planetsrv:~$ sudo do-release-upgrade
Checking for a new Ubuntu release
Your Ubuntu release is not supported anymore.
For upgrade information, please visit:
http://www.ubuntu.com/releaseendoflife
Please install all available updates for your release before upgrading.
It just tells me that I'm EOL -- I know that, that's why I'm trying to upgrade! :) The link just gives the release schedule; I don't see any instructions or tips about upgrading from an EOL'd version.
When running apt update, I get nothing but 404 errors:
anthony@planetsrv:~$ sudo apt update
Ign:1 http://ports.ubuntu.com/ubuntu-ports impish InRelease
Ign:2 http://ports.ubuntu.com/ubuntu-ports impish-updates InRelease
Ign:3 http://ports.ubuntu.com/ubuntu-ports impish-backports InRelease
Ign:4 http://ports.ubuntu.com/ubuntu-ports impish-security InRelease
Err:5 http://ports.ubuntu.com/ubuntu-ports impish Release
404 Not Found [IP: 2620:2d:4000:1::19 80]
Err:6 http://ports.ubuntu.com/ubuntu-ports impish-updates Release
Err:7 http://ports.ubuntu.com/ubuntu-ports impish-backports Release
Err:8 http://ports.ubuntu.com/ubuntu-ports impish-security Release
Reading package lists... Done
E: The repository 'http://ports.ubuntu.com/ubuntu-ports impish Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://ports.ubuntu.com/ubuntu-ports impish-updates Release' no longer has a Release file.
E: The repository 'http://ports.ubuntu.com/ubuntu-ports impish-backports Release' no longer has a Release file.
E: The repository 'http://ports.ubuntu.com/ubuntu-ports impish-security Release' no longer has a Release file.
Same with apt upgrade:
anthony@planetsrv:~$ sudo apt upgrade
Building dependency tree... Done
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
libfwupdplugin1
Use 'sudo apt autoremove' to remove it.
The following packages will be upgraded:
apt apt-utils cloud-init gtk-update-icon-cache keyutils libapt-pkg6.0 libgtk-3-0 libgtk-3-bin libgtk-3-common libkeyutils1 libnss-systemd libpam-systemd librados2 librbd1 libsystemd0 libudev1
python3-distupgrade snapd systemd systemd-sysv systemd-timesyncd ubuntu-advantage-tools ubuntu-release-upgrader-core udev
24 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 41.2 MB of archives.
After this operation, 122 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Err:1 http://ports.ubuntu.com/ubuntu-ports impish-updates/main arm64 libnss-systemd arm64 248.3-1ubuntu8.6
Err:2 http://ports.ubuntu.com/ubuntu-ports impish-updates/main arm64 libsystemd0 arm64 248.3-1ubuntu8.6
Err:3 http://ports.ubuntu.com/ubuntu-ports impish-updates/main arm64 systemd-timesyncd arm64 248.3-1ubuntu8.6
...snipping repetitive similar lines, you get the idea :)...
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/systemd/libnss-systemd_248.3-1ubuntu8.6_arm64.deb 404 Not Found [IP: 2620:2d:4000:1::19 80]
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/systemd/libsystemd0_248.3-1ubuntu8.6_arm64.deb 404 Not Found [IP: 2620:2d:4000:1::19 80]
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/systemd/systemd-timesyncd_248.3-1ubuntu8.6_arm64.deb 404 Not Found [IP: 2620:2d:4000:1::19 80]
...snipping some more...
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I came across this question which suggests that the packages have moved to old-releases.ubuntu.com or us.archive.ubuntu.com, but neither of those seem to work for me. I also came across this question where the resolution seemed to be a complete wipe and reinstall, which I'd rather avoid.
Here's my current sources.list (stripped of comments):
deb http://ports.ubuntu.com/ubuntu-ports impish main restricted
deb http://ports.ubuntu.com/ubuntu-ports impish-updates main restricted
deb http://ports.ubuntu.com/ubuntu-ports impish universe
deb http://ports.ubuntu.com/ubuntu-ports impish-updates universe
deb http://ports.ubuntu.com/ubuntu-ports impish multiverse
deb http://ports.ubuntu.com/ubuntu-ports impish-updates multiverse
deb http://ports.ubuntu.com/ubuntu-ports impish-backports main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports impish-security main restricted
deb http://ports.ubuntu.com/ubuntu-ports impish-security universe
deb http://ports.ubuntu.com/ubuntu-ports impish-security multiverse
How should I proceed to update my system? Can I just update the release name in my sources.list like I would in Debian, and do the big upgrade that way? Or is there any way to get the original tools (do-release-upgrade) to work properly?
