I installed elementary OS and e17 on my Ubuntu 12.04 from ppas. After logout and login, right click on desktop is not working in gnome and unity but working in file manger.When I login into Pantheon session, I don't find an option to open Home folder and my login display manager theme is also changed.I want to get back to default Ubuntu login theme.Can i change the login theme with simple-lightdm manager. I dont want to mess up my system.Please hemp me how to fix these.
Try this:
- Go to the Software Center, type Advanced Settings in search, and install the Advanced Settings (Gnome Tweak) tool.
- Click on the launcher (top left), type
advancedand run the Advanced Settings tool. Under Desktop, set the first item "Have file manager handle the desktop" to ON. If it is ON, turn off then on again.
- That should hopefully fix the right-click issue.
- 141,990
That happens when the desktop icons are disabled. You can use the permanent fix of going to dconf-editor, org > gnome > desktop > background and click show desktop icons, then reboot and it's solved.
I hate the desktop icons, but unity disables other features if this is removed.
- 72,312
I am running Ubuntu 18.04. Here is how I rectified this problem (actually discovered something)
- Install GNOME Tweak
- Run it (obviously)
- Click on the Keyboard and mouse Tab
- There is an option for workstation emulation
- You can select your profile and live happily ever after.
- 72,312
please try the following to repair the rightclick-behaviour of the desktop:
Install gconf-editor and open it
sudo apt-get install gconf-editor && gconf-editorGo to apps > nautilus > preferences
- Check whether the tick at the 'show desktop' entry is set.
- If not, activate this item.
- Restart the machine or log out and log in back.
These steps should clear your problem with the desktop :)
- 1,083
The same situation happened to me after I did an upgrade of the system to Ubuntu 18.04. Here's my solution:
You have to make sure that you have installed Gnome Tweaks, after that, go to the section Keyboard & Mouse, at the bottom there are three options, make sure that the option Area is selected.
- 11,750
- 111
