I tried updating in many ways but I've been running into the same display basically saying that 6 packages werent upgraded. (you can see the whole question in my profile) and after some troubleshooting i've began to try and install packages individually but i'm not quite the tech savvy yet but wanted to know if the command i used was correctly utilized.
dcg@dcg-IdeaPad-5-15ITL05:~$ sudo apt-get --only-upgrade install jammy-updates 12ubuntu4.2 amd64 [upgradable from: 12ubuntu4.1]
Reading package lists... Done
Building dependency tree... Done
E: Unable to locate package jammy-updates
E: Unable to locate package 12ubuntu4.2
E: Couldn't find any package by glob '12ubuntu4.2'
E: Couldn't find any package by regex '12ubuntu4.2'
E: Unable to locate package amd64
E: Unable to locate package [upgradable
E: Couldn't find any package by glob '[upgradable'
E: Regex compilation error - Unmatched [, [^, [:, [., or [=
E: Couldn't find any package by regex '[upgradable'
E: Unable to locate package from:
E: Unable to locate package 12ubuntu4.1]
E: Couldn't find any package by glob '12ubuntu4.1]'
E: Couldn't find any package by regex '12ubuntu4.1]'
Can you let me know if it was correctly used? (i doubt it since it couldnt find any package...)
Distributor ID: Ubuntu
Description:    Ubuntu 22.04 LTS
Release:    22.04
Codename:   jammy
Thomas Ward
  • 78,878
The only proper way to install packages needing updates are through sudo apt update && sudo apt full-upgrade because any packages which have new dependencies will get those new dependencies pulled in and updated.
There is no jammy-updates package nor any regex pattern match that'll be a specific version in the string. Your message simply said there are 6 packages to update, not the packages you needed to update/upgrade. apt has the inbuilt commands already to do the upgrade, you just have to instruct it to like I specified above.
Thomas Ward
  • 78,878
