I installed Ubuntu successfully and am now trying to install KDE, but I am getting errors.
During installation I get the following error:
The following packages have unmet dependencies: muon : Depends: software-properties-qt but it is not installable E: Unable to correct problems, you have held broken packages.
I have tried several commands such as:
sudo apt update
sudo apt--fix-missing update
sudo apt install -f
apt autoremove
apt dist-upgrade
apt --fix broken install
It shows all packages are up to date, or 0 new files found, 0 upgrade, 0 deleted, or 0 packages needing to be fixed
Then I try and use sudo dpkg --configure -a
That command doesn't do anything, as it just give me new blank line
After entering dpkg --configure
Ivye tried to find the file in question but I can't find it.
I could make it easier and just install Kubuntu, but I already have personal files and accounts linked.
device im using
I'm new to using Ubuntu and Linux.
karel
  • 122,292
  • 133
  • 301
  • 332
