System (dual boot, Ubuntu 22.04 and Windows 10) does not boot: once selected Ubuntu at dual boot, I receive error message “mtd device must be supplied” - It shows on two lines, then boot does not go on. I tried to boot through recovery mode, but the problem persists. Actually, the recovery mode seems to freeze as well. I had to apply a forced shut down in order to attempt to reboot the laptop. The problem has appeared last night (the system is constantly updated and upgraded).
In my case, the problem was caused by a full hard drive.
You need to:
  1. Boot to recovery mode (here is how: https://askubuntu.com/a/859640/270345 )
  2. In Recovery Menu, enter root shell prompt
  3. While in shell:
  • Enter df -h to check if your disk is indeed 100% full
  • If yes, delete some large files
This command might be helpful to find largest directories in your /home directory (might take a while to process):
$ sudo du -a /home | sort -n -r | head -n 20
Piotrek
  • 401
