I didn't see any relevant result searching for my 'apt corruption' problem except for this topic. I remember setting up VirtualBox and somehow managed it to work but, this Terminal output keeps repeating and maybe other hidden consequences.
So I tested:
sudo dpkg --configure -a
Hoping it would reinitialize apt to default parameters. But, it keeps repeating the following text after every "apt install" command.
Setting up virtualbox-dkms (6.1.16-dfsg-6~ubuntu1.20.04.2) ...
Removing old virtualbox-6.1.16 DKMS files...
Deleting module version: 6.1.16
completely from the DKMS tree.
Done.
Loading new virtualbox-6.1.16 DKMS files...
Building for 5.13.0-52-generic
Building initial module for 5.13.0-52-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/virtualbox-dkms.0.crash'
Error! Bad return status for module build on kernel: 5.13.0-52-generic (x86_64)
Consult /var/lib/dkms/virtualbox/6.1.16/build/make.log for more information.
dpkg: error processing package virtualbox-dkms (--configure):
installed virtualbox-dkms package post-installation script subprocess returned error exit status 10
virtualbox-dkms
output for 'cat /var/lib/dkms/virtualbox/6.1.16/build/make.log' is:
DKMS make.log for virtualbox-6.1.16 for kernel 5.13.0-52-generic (x86_64)
Sat 9 Jul 11:02:23 +04 2022
make: Entering directory '/usr/src/linux-headers-5.13.0-52-generic'
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/linux/SUPDrv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/SUPDrv.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/SUPDrvGip.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/SUPDrvSem.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/SUPDrvTracer.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/SUPLibAll.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/alloc-r0drv.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/initterm-r0drv.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/memobj-r0drv.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/mpnotification-r0drv.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/powernotification-r0drv.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/assert-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/alloc-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/initterm-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/memobj-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/memuserkernel-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/mp-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/mpnotification-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/process-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/rtStrFormatKernelAddress-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/semevent-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/semeventmulti-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/semfastmutex-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/semmutex-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/spinlock-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/thread-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/thread2-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/threadctxhooks-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/time-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/timer-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/generic/semspinmutex-r0drv-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/alloc/alloc.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/checksum/crc32.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/checksum/ipv4.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/checksum/ipv6.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/err/RTErrConvertFromErrno.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/err/RTErrConvertToErrno.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/err/errinfo.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/log/log.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/log/logellipsis.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/log/logrel.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/log/logrelellipsis.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/log/logcom.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/log/logformat.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/misc/RTAssertMsg1Weak.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/misc/RTAssertMsg2.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/misc/RTAssertMsg2Add.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/misc/RTAssertMsg2AddWeak.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/misc/RTAssertMsg2AddWeakV.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/misc/RTAssertMsg2Weak.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/misc/RTAssertMsg2WeakV.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/misc/assert.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/misc/handletable.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/misc/handletablectx.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/misc/thread.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/RTStrCat.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/RTStrCopy.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/RTStrCopyEx.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/RTStrCopyP.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/RTStrNCmp.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/RTStrNLen.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/stringalloc.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/strformat.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/strformatnum.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/strformatrt.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/strformattype.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/strprintf.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/string/strtonum.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/table/avlpv.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/time/time.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/r0drv/linux/RTLogWriteDebugger-r0drv-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/RTAssertShouldPanic-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/RTLogWriteStdErr-stub-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/RTLogWriteStdOut-stub-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/RTLogWriteUser-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/RTMpGetArraySize-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/RTMpGetCoreCount-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/RTSemEventWait-2-ex-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/RTSemEventWaitNoResume-2-ex-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/RTSemEventMultiWait-2-ex-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/RTSemEventMultiWaitNoResume-2-ex-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/RTTimerCreate-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/errvars-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/mppresent-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/generic/uuid-generic.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/VBox/log-vbox.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/common/alloc/heapsimple.o
LD [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxdrv/vboxdrv.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/linux/VBoxNetFlt-linux.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/VBoxNetFlt.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/SUPR0IdcClient.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/SUPR0IdcClientComponent.o
CC [M] /var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/linux/SUPR0IdcClient-linux.o
/var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/linux/VBoxNetFlt-linux.c: In function ‘vboxNetFltNeedsLinkState’:
/var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/linux/VBoxNetFlt-linux.c:1761:47: error: dereferencing pointer to incomplete type ‘const struct ethtool_ops’
1761 | if (pDev->ethtool_ops && pDev->ethtool_ops->get_drvinfo)
/var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/linux/VBoxNetFlt-linux.c:1763:32: error: storage size of ‘Info’ isn’t known
1763 | struct ethtool_drvinfo Info;
/var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/linux/VBoxNetFlt-linux.c:1766:20: error: ‘ETHTOOL_GDRVINFO’ undeclared (first use in this function)
1766 | Info.cmd = ETHTOOL_GDRVINFO;
/var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/linux/VBoxNetFlt-linux.c:1766:20: note: each undeclared identifier is reported only once for each function it appears in
/var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/linux/VBoxNetFlt-linux.c:1763:32: warning: unused variable ‘Info’ [-Wunused-variable]
make[2]: *** [scripts/Makefile.build:281: /var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt/linux/VBoxNetFlt-linux.o] Error 1
make[1]: *** [scripts/Makefile.build:524: /var/lib/dkms/virtualbox/6.1.16/build/vboxnetflt] Error 2
make: *** [Makefile:1879: /var/lib/dkms/virtualbox/6.1.16/build] Error 2
make: Leaving directory '/usr/src/linux-headers-5.13.0-52-generic'
additional error in my "Software and Updates". Appears when I'm trying to save with new settings.
