I'm trying to access Nautilus settings in order to change default list columns (and more generally to explore all available options). The setting pane should look like this :
But...
  1. The "settings" option does not show in the top menu "Files" dropdown :
  1. The "preferences" option in any Files window (through the hamburger menu) leads to settings relative to the window itself, they don't apply to the whole filesystem :
  1. In GNOME Tweaks, there is no option relative to top menu that could help :
  1. Using dconf didn't help me, as it does'nt handle all Nautilus settings (and using gsettings gets a little too technical to me...).
I went through several topics on AskUbuntu.com :
Thank you very much,
Best regards,
K.
PS: I have no experience about this issue on previous releases of Ubuntu or other OS with GNOME, as I'm a Linux newbie and I just started from Ubuntu 22.04 LTS.
KiR
  • 13
It shouldn't. Applications change, and how the interface looks is actually decided upon by the developers. Files 40 changed quite a bit.
You demonstrated that you actually can access the preferences in Files. The preference pane is now organized the way you see in your picture. Instead of tabs, there is a single pane with sections. Several options are not anymore exposed, or have been removed, including the behavior when clicking executables, or removing a confirmation before deleting the trash.
vanadium
  • 97,564
