Yesterday I successfully dual-booted and installed windows on the part of the SSD in my system. The Windows and Linux parts work well, but the disk partition I have reserved for Windows appears in the Devices part of Linux.
Files
How do I make this partition not appear in Linux? Will Windows files be damaged if I unmount using the GParted?
GParted
Linux will not damage your Windows files or your Windows partition if you unmount it.
If you want to hide it for one session, you can right-click it in your filemanager and choose the option 'hide'.
See also How to hide a(n) (NTFS) partition from ubuntu and https://ubuntuforums.org/archive/index.php/t-1247829.html. You can also watch https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj90u7Jm8b4AhUFxYUKHeY-BaEQtwJ6BAghEAI&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DQ14k1hIw8nw&usg=AOvVaw2YSu_c_GUT2M8Q639ChGtc on Youtube ( hiding unmounted partitions .
Joepie Es
  • 1,570
You can unmount it using umount itself or GParted or other tools.
But, If don't need your Windows partition and you want to make it gone, you can remove the corresponding line from your /etc/fstab file.
