-1
I've just installed ubuntu and my earphones are having weird pop noices. Other people had this problem and they solved it. But when I copy their command and try to run it gives me "Permission denied". What should I do?
The source commands " Cracking and popping sound from left side of headphone on Front Left/Right sound test ".
Caser
The instructions you seem to be referring to don't make clear that you also need to give that script you create in /usr/local/bin execute permissions before anyone is allowed to run it.
Only then can you run the script with sudo.
First do this with the command:
sudo chmod +x /usr/local/bin/FILENAME
Martin Thornton
  • 5,996
  • 32
  • 43
