I've upgraded my Kubuntu 21.10 VM today, to 22.04 LTS. The install went fine, and everythin was upgraded. After it reboot, however, I'm simply met with the following message:
SMBus base address uninitialized - upgrade BIOS or use force_addr=0xaddr
The KDE environment never boots, even if I leave it awhile.
I can switch to a different terminal, using Ctrl+Alt+F2, for example, and log into the terminal, but I cannot get the GUI to load.
I've seen this question, SMBus/ BIOS error while booting Ubuntu in VirtualBox, which has the same error but in VirtualBox, and tried blacklisting both i2c_piix4 and intel_rapl; same result. Checking lsmod afterwards, it was still loaded even though blacklisted. I also tried putting the black list in the file /etc/modprobe.d/no_i2c_piix4.conf; same result and still loaded.
Does anyone have any ideas why this is happening, and how to fix?
Terrance
  • 43,712
Larnu
  • 254
It turned out the problem here was that the VM was a Gen 1 VM, and 22.04 needs a Gen 2 VM (or at least, I could not get it to work as a Gen 1 VM).
Upgrading an existing VM from a Gen 1 to a Gen 2 isn't possible. What you can do, however, is delete the existing VM (make sure you don't delete it's vhd files), and then create a new Gen 2 VM and attack the old vhd files to it. This should "upgrade" the system to a Gen 2; though apparently it is a 1 way process.
I also noted, through research, that you should disable Secure Boot on the VM; I had this off any way, but if you do have it enabled and are having difficulty, then I would suggest trying to disable it.
Larnu
  • 254
Got similar error. The error message I got is Unable to find a valid framebuffer device, which is prompted in /var/log/Xorg.0.log.
Copy from the link in proxmox forum, it seems that the display device could not be found. To fix:-
  1. Ctrl + Alt + F2 to enter console
  2. lspci to find pci id of the VGA device, e.g. 00:08.0
  3. cd /usr/share/X11/xorg.conf.d
  4. sudo nano <your config name>.conf, e.g. hyperv.conf
  5. Put below content in the file. Your PCI ID may be different
     Section "Device"
         Identifier "Card0"
         Driver "fbdev"
         BusID "pci0:08:0:0:"
     EndSection
  6. Save and close
  7. startx
  8. If success, you should immediately see the GUI loaded.
For information. I got this problem when converting a lubuntu from KVM and VM-Workstation to Hyper-V platform.
Ref: https://forum.proxmox.com/threads/generic-solution-when-install-gets-framebuffer-mode-fails.111577/
