after i upgraded to 22.04 my wifi is showing no networks I have reseted my network settings many times but no result I have even downgraded the kernel from 5.15 to old 5.13 still no result
Asked
Active
Viewed 964 times
It's because you need to tell netplan to use NetworkManager. You will have to add a line to the configuration file of netplan. So edit the /etc/netplan/ 00-...-wifi.yaml file with sudo privileges.
Find the flowing lines:
network:
version: 2
and add the line:
renderer: NetworkManager
so it will now be like this:
network:
version: 2
Now, to activate the new line, you can type in the terminal either:
sudo netplan apply
which will apply the new line, or:
sudo netplan try
which will only try to apply for a few minutes, and reverts back automatically, if you don't approve it.
The Wi-Fi should start showing up, immediately.
BeastOfCaerbannog
- 16,703
raban
- 21
