When I type sudo apt upgrade I get this message
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
linux-image-5.13.0-40-generic : Depends: linux-modules-5.13.0-40-generic but it is not going to be installed
E: Broken packages
I tried solutions on google but they aren't working. I am new to this so please explain accordingly. I am also not able to change brightness using keyboard. Edit1:
I tried sudo apt update
Hit:1 http://in.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://in.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://in.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:4 http://security.ubuntu.com/ubuntu focal-security InRelease
8 packages can be upgraded. Run 'apt list --upgradable' to see them.
I tried apt list --upgradable
Listing... Done
dpkg-dev/focal-security,focal-security 1.19.7ubuntu3.2 all [upgradable from: 1.19.7ubuntu3]
dpkg/focal-security 1.19.7ubuntu3.2 amd64 [upgradable from: 1.19.7ubuntu3]
gir1.2-javascriptcoregtk-4.0/focal-security 2.36.2-0ubuntu0.20.04.1 amd64 [upgradable from: 2.36.0-0ubuntu0.20.04.3]
gir1.2-webkit2-4.0/focal-security 2.36.2-0ubuntu0.20.04.1 amd64 [upgradable from: 2.36.0-0ubuntu0.20.04.3]
libdpkg-perl/focal-security,focal-security 1.19.7ubuntu3.2 all [upgradable from: 1.19.7ubuntu3]
libjavascriptcoregtk-4.0-18/focal-security 2.36.2-0ubuntu0.20.04.1 amd64 [upgradable from: 2.36.0-0ubuntu0.20.04.3]
libwebkit2gtk-4.0-37/focal-security 2.36.2-0ubuntu0.20.04.1 amd64 [upgradable from: 2.36.0-0ubuntu0.20.04.3]
orca/focal-security,focal-security 3.36.2-1ubuntu1~20.04.2 all [upgradable from: 3.36.2-1ubuntu1~20.04.1]
sudo apt install linux-modules-5.13.0-40-generic
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 8 not upgraded.
3 not fully installed or removed.
Need to get 0 B/28.5 MB of archives.
After this operation, 100 MB of additional disk space will be used.
Selecting previously unselected package linux-modules-5.13.0-40-generic.
(Reading database ... 187741 files and directories currently installed.)
Preparing to unpack .../linux-modules-5.13.0-40-generic_5.13.0-40.45~20.04.1_amd
64.deb ...
Unpacking linux-modules-5.13.0-40-generic (5.13.0-40.45~20.04.1) ...
dpkg: dependency problems prevent configuration of linux-modules-5.13.0-40-gener
ic:
linux-modules-5.13.0-40-generic depends on linux-image-5.13.0-40-generic | linu
x-image-unsigned-5.13.0-40-generic; however:
Package linux-image-5.13.0-40-generic is not installed.
Package linux-image-unsigned-5.13.0-40-generic is not installed.
dpkg: error processing package linux-modules-5.13.0-40-generic (--configure):
dependency problems - leaving unconfigured
Setting up linux-image-5.13.0-41-generic (5.13.0-41.46~20.04.1) ...
No apport report written because the error message indicates its a followup erro
r from a previous failure.
Setting up linux-image-5.13.0-44-generic (5.13.0-44.49
~20.04.1) ...
Processing triggers for linux-image-5.13.0-41-generic (5.13.0-41.46~20.04.1) ...
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.13.0-41-generic
/etc/kernel/postinst.d/zz-update-grub:
Sourcing file /etc/default/grub' /usr/sbin/grub-mkconfig: 34: /etc/default/grub: Syntax error: EOF in backquote s ubstitution run-parts: /etc/kernel/postinst.d/zz-update-grub exited with return code 2 dpkg: error processing package linux-image-5.13.0-41-generic (--configure): installed linux-image-5.13.0-41-generic package post-installation script subpro cess returned error exit status 1 Processing triggers for linux-image-5.13.0-44-generic (5.13.0-44.49~20.04.1) ... /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-5.13.0-44-generic /etc/kernel/postinst.d/zz-update-grub: Sourcing file/etc/default/grub'
ubstitution
dpkg: error processing package linux-image-5.13.0-44-generic (--configure):
installed linux-image-5.13.0-44-generic package post-installation script subpro
df -h;df -i
Filesystem Size Used Avail Use% Mounted on
udev 7.5G 0 7.5G 0% /dev
tmpfs 1.6G 2.3M 1.6G 1% /run
/dev/nvme0n1p6 46G 39G 5.0G 89% /
tmpfs 7.6G 0 7.6G 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 7.6G 0 7.6G 0% /sys/fs/cgroup
/dev/nvme0n1p1 256M 33M 224M 13% /boot/efi
/dev/loop0 128K 128K 0 100% /snap/bare/5
/dev/loop2 45M 45M 0 100% /snap/snapd/15904
/dev/loop1 228M 228M 0 100% /snap/code/96
/dev/loop3 62M 62M 0 100% /snap/core20/1494
/dev/loop4 111M 111M 0 100% /snap/core/12834
/dev/loop5 220M 220M 0 100% /snap/code/97
/dev/loop6 45M 45M 0 100% /snap/snapd/15534
/dev/loop7 82M 82M 0 100% /snap/gtk-common-themes/1534
/dev/loop8 62M 62M 0 100% /snap/core20/1434
/dev/loop9 112M 112M 0 100% /snap/core/13250
/dev/loop10 66M 66M 0 100% /snap/gtk-common-themes/1519
/dev/loop11 55M 55M 0 100% /snap/snap-store/558
tmpfs 1.6G 20K 1.6G 1% /run/user/125
/dev/loop12 249M 249M 0 100% /snap/gnome-3-38-2004/99
tmpfs 1.6G 60K 1.6G 1% /run/user/1000
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 1964052 637 1963415 1% /dev
tmpfs 1972933 1176 1971757 1% /run
/dev/nvme0n1p6 3055616 400215 2655401 14% /
tmpfs 1972933 1 1972932 1% /dev/shm
tmpfs 1972933 5 1972928 1% /run/lock
tmpfs 1972933 19 1972914 1% /sys/fs/cgroup
/dev/nvme0n1p1 0 0 0 - /boot/efi
/dev/loop0 29 29 0 100% /snap/bare/5
/dev/loop2 484 484 0 100% /snap/snapd/15904
/dev/loop1 3914 3914 0 100% /snap/code/96
/dev/loop3 11789 11789 0 100% /snap/core20/1494
/dev/loop4 12847 12847 0 100% /snap/core/12834
/dev/loop5 3914 3914 0 100% /snap/code/97
/dev/loop6 484 484 0 100% /snap/snapd/15534
/dev/loop7 76177 76177 0 100% /snap/gtk-common-themes/1534
/dev/loop8 11789 11789 0 100% /snap/core20/1434
/dev/loop9 12848 12848 0 100% /snap/core/13250
/dev/loop10 65095 65095 0 100% /snap/gtk-common-themes/1519
/dev/loop11 17311 17311 0 100% /snap/snap-store/558
tmpfs 1972933 45 1972888 1% /run/user/125
/dev/loop12 17495 17495 0 100% /snap/gnome-3-38-2004/99
tmpfs 1972933 104 1972829 1% /run/user/1000
sudo dpkg --configure -a && sudo apt -f install
dpkg: dependency problems prevent configuration of linux-modules-5.13.0-40-generic:
linux-modules-5.13.0-40-generic depends on linux-image-5.13.0-40-generic | linux-image-unsigned-5.13.0-40-generic; however:
Setting up linux-image-5.13.0-44-generic (5.13.0-44.49~20.04.1) ...
Sourcing file /etc/default/grub' Sourcing file/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.13.0-44-generic
Found initrd image: /boot/initrd.img-5.13.0-44-generic
Found linux image: /boot/vmlinuz-5.13.0-41-generic
Found initrd image: /boot/initrd.img-5.13.0-41-generic
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings
done
done
