I'm relatively new to Linux. I recently had a functioning Ubuntu 20.04 which wasn't recognizing that I had plugged in a display via HDMI to my ASUS ZenBook laptop. I read a couple of articles and found the sudo ubuntu-drivers autoinstall command which suggested that updating the Nvidia graphics driver might fix the issue.
After updating all my drivers as well as Nvidia, my laptop couldn't boot. It would simply cycle between the boot window and a message saying "SGX disabled by BIOS". Using purge I removed all Nvidia drivers from my machine and managed to boot to desktop, however there are now several drivers that are seeming to fail, presumably from the autoinstall. These include important things such as the touchpad and wireless connection functionality.
I also attempted the steps detailed in this post which suggests installing ubuntu-desktop post purge.
Is there a command or process I can use to basically purge all faulty/incompatible drivers I may have installed with autoinstall, perhaps back to the base Ubuntu 20.04 image as my machine was functional out the box with a fresh installation?
EDIT:
uname -a
Linux james-ZenBook-UX535LI-UX535LI 5.15.0-33-generic #34-Ubuntu SMP Wed May 18 13:34:26 UTC 2022 x86_64 x86_64 GNU/Linux
lspci -nnk | grep -A2 0280
Network controller [0280]: Intel Corporation Comet Lake PCH CNVi WiFi [8086:06f0]
DeviceName: WLAN
Subsystem: Intel Corporation Wi-Fi 6 AX201 160MHz [8086:0074]
James
  • 131
To remove all the proprietary nvidia packages run the following commands.
sudo apt update
sudo apt-get remove '^nvidia'
sudo apt autoremove
sudo reboot
Since you made some other big changes to your installed software besides uninstalling the Nvidia proprietary graphics drivers, I wouldn't automatically assume that the autoinstall option of ubuntu-drivers caused so many things to fail. In fact you might need to reverse some other commands.
You may be facing a situation which requires you to either reinstall Ubuntu 20.04 or fresh install Ubuntu 22.04. If your laptop is a recent model, a fresh install of Ubuntu 22.04 will get you out of reverse gear and give you a more up-to-date kernel and proprietary graphics drivers.
karel
  • 122,292
  • 133
  • 301
  • 332
