Since I had driver problems with nouveau on my Thinkpad (flickering external monitor on docking station) I switched to nvidia-390 and also to nvidia-396 both without success (didn't even recognize the external screen on docking station).
Now I want to switch back to nouveau since then at least the external monitor worked if I connect it via mini-dp.
However I cannot switch back anymore. I did the following steps:
  • sudo apt-get purge '*-nvidia-*'
  • removed /etc/modprobe.d/blacklist-nouveau.conf (which I created when installing nvidia)
  • sudo update-initramfs -u
  • sudo reinstall xserver-xorg-core libgl1-mesa-glx xserver-xorg-video-nouveau
  • There was no /etc/X11/xorg.conf to remove or to modify
  • reboot
However then lspci -nnk | grep -iA2 vga returns that
00:02.0 VGA compatible controller [0300]: Intel Corporation 3rd Gen Core processor Graphics Controller [8086:0166] (rev 09)
    Subsystem: Lenovo 3rd Gen Core processor Graphics Controller [17aa:21f5]
    Kernel driver in use: i915
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GK107GLM [Quadro K2000M] [10de:0ffb] (rev a1)
    Subsystem: Lenovo GK107GLM [Quadro K2000M] [17aa:21f5]
    Kernel modules: nvidiafb, nouveau
I.e. additionally to nouveau there seems to be nvidiafb active. Then I tried to blacklist nvidiafb without success.
I also tried to disable framebuffer as described in the arch wiki also without success.
The problem is that this configuration doesn't recognize any external monitor even on mini-dp. I just realized that even VGA doesn't work.
Any idea of how I can make it work?
Are there any settings or files I should check to diagnose the cause of the problem?
student
  • 2,352
You should uninstall completely the nvidia driver.
sudo apt autoremove *nvidia-*
Be careful what dependencies are removed before validating the uninstall !!
ob2
  • 3,653
