I'm using ubuntu 10.04 with qemu-kvm installed. I bridged my eth0 to br0. My problem is that The host OS loses connection. Here is my interfaces file
 auto lo
 iface lo inet loopback
 auto eth0
 iface eth0 inet manual
 auto br0
 iface br0 inet dhcp
         bridge_ports eth0
         bridge_stp off
         bridge_fd 0
         bridge_maxwait 0
gerger09
Your interfaces file looks right. Are you sure it isn't an issue with your network setup? How are you determining that the host OS is losing connection (i.e. dropped ping packets, trouble downloading files, etc)?
You may need to give qemu the inheritable CAP_NET_ADMIN capability, for 64-bit:
sudo setcap cap_net_admin=ei /usr/bin/qemu-system-x86_64
or for 32-bit:
For detailed instructions on setting up a bridged NIC for KVM, see my blog post, http://john.wesorick.com/2012/01/setting-up-bridged-network-interface.html.
reverendj1
  • 16,403
Give a try to these two scripts I posted a couple of minutes ago, maybe they can help you out with your problem.
Avio
  • 3,098
You haven't said anything about how your guests are defined. This reference suggests using the paravirtualized virtio rather than the default network NIC model for performance and reliability.
Per the reference: "This improves the network performances by a lot (nearly a factor of 10) and corrects an issue some people reported with their network connections going away after a period of time or data transfer."
John S Gruber
  • 13,436
