Update solution
I had to install docker-engine from the centos extras repository. These were the steps:
First, remove docker
sudo yum remove docker \
                  docker-client \
                  docker-client-latest \
                  docker-common \
                  docker-latest \
                  docker-latest-logrotate \
                  docker-logrotate \
                  docker-engine
Then add the docker-ce repo:
sudo yum install -y yum-utils
sudo yum-config-manager \
    --add-repo \
    https://download.docker.com/linux/centos/docker-ce.repo
Then install docker-ce
sudo yum install docker-ce docker-ce-cli containerd.io docker-compose-plugin
Finally start docker-ce
sudo systemctl start docker
First let me state that the question about updating PUBKEY (How do I fix the GPG error "NO_PUBKEY"?) does not solve this issue as I've mentioned below.
The following is my process:
docker run --rm -it ubuntu:22.04 bash -l
This downloads the ubuntu 22.04 image, starts a container, and drops me into a root shell. This process is the same for any host OS I've tried (MacOS, CentOS, Amazon Linux).
The next command, run inside the root shell, works on MacOS and Amazon Linux but not on Cent OS host:
apt update
On a CentOS host, I get this:
root@b40f3c9766e7:/# apt update
Get:1 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
Get:2 http://archive.ubuntu.com/ubuntu jammy InRelease [270 kB]
Err:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [109 kB]
Err:2 http://archive.ubuntu.com/ubuntu jammy InRelease
Err:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
Get:4 http://archive.ubuntu.com/ubuntu jammy-backports InRelease [90.7 kB]
Err:4 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
Reading package lists... Done
W: http://security.ubuntu.com/ubuntu/dists/jammy-security/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ubuntu-keyring-2012-cdimage.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
W: http://security.ubuntu.com/ubuntu/dists/jammy-security/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ubuntu-keyring-2018-archive.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
W: GPG error: http://security.ubuntu.com/ubuntu jammy-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
E: The repository 'http://security.ubuntu.com/ubuntu jammy-security InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: http://archive.ubuntu.com/ubuntu/dists/jammy/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ubuntu-keyring-2012-cdimage.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
W: http://archive.ubuntu.com/ubuntu/dists/jammy/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ubuntu-keyring-2018-archive.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
W: GPG error: http://archive.ubuntu.com/ubuntu jammy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
E: The repository 'http://archive.ubuntu.com/ubuntu jammy InRelease' is not signed.
W: http://archive.ubuntu.com/ubuntu/dists/jammy-updates/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ubuntu-keyring-2012-cdimage.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
W: http://archive.ubuntu.com/ubuntu/dists/jammy-updates/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ubuntu-keyring-2018-archive.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
W: GPG error: http://archive.ubuntu.com/ubuntu jammy-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
E: The repository 'http://archive.ubuntu.com/ubuntu jammy-updates InRelease' is not signed.
W: http://archive.ubuntu.com/ubuntu/dists/jammy-backports/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ubuntu-keyring-2012-cdimage.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
W: http://archive.ubuntu.com/ubuntu/dists/jammy-backports/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ubuntu-keyring-2018-archive.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
W: GPG error: http://archive.ubuntu.com/ubuntu jammy-backports InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
E: The repository 'http://archive.ubuntu.com/ubuntu jammy-backports InRelease' is not signed.
E: Problem executing scripts APT::Update::Post-Invoke 'rm -f /var/cache/apt/archives/*.deb /var/cache/apt/archives/partial/*.deb /var/cache/apt/*.bin || true'
E: Sub-process returned an error code
I tried to add the PUBKEY using instructions from How do I fix the GPG error "NO_PUBKEY"? but I get this error:
E: gnupg, gnupg2 and gnupg1 do not seem to be installed, but one of them is required for this operation
I cannot install any of these because I cannot use apt, so what's the way out of this situation?
Does anyone know why this works on MacOS & Amazon Linux but not on CentOS?
Also, this works on Ubuntu 18.04 and Ubuntu 20.04. It only fails on 22.04.
bluesmoon
  • 143
EDIT: After looking at this thoroughly I realized what I had done here was to just use the default yum-provided version of docker in @extras.
I removed these:
Removing:
 docker                          x86_64                   2:1.13.1-209.git7d71120.el7.centos                    @extras                    64 M
 docker-client                   x86_64                   2:1.13.1-209.git7d71120.el7.centos                    @extras                    13 M
 docker-common                   x86_64                   2:1.13.1-209.git7d71120.el7.centos                    @extras                   4.4 k
I then installed the correct method from docker https://docs.docker.com/engine/install/centos/
The issue is now entirely resolved. Below is my original delve into this so you can see a bit of my course in looking through this one.
I am seeing the same thing on CentOS 7 based Docker containers that are running literally every single public Ubuntu image - for whatever reason. I just slashed through the various versions and it's something indicating there is some lower level issue / bug between Docker & CentOS 7 when it comes to this routine. What I genuinely do not know. Still digging.
That's the problematic line. _apt is on all systems that I am seeing though the userID tends to be different.
Broken system:
root@69a789b8893e:/# grep _apt /etc/passwd /etc/shadow /etc/group
/etc/passwd:_apt:x:100:65534::/nonexistent:/usr/sbin/nologin
Working native system:
_apt:x:105:65534::/nonexistent:/usr/sbin/nologin
GID will always be common as 65534 so that makes sense. What doesn't here is that literally every file and directory is correct on perms & ownership. 0755 is always the default within /etc/apt.
root@69a789b8893e:/# find /etc/apt -type d -ls
  1464065      0 drwxr-xr-x   8 root     root          143 Apr 28 12:01 /etc/apt
 68555287      0 drwxr-xr-x   2 root     root          213 Apr 28 12:04 /etc/apt/apt.conf.d
135370920      0 drwxr-xr-x   2 root     root            6 Apr  8 10:22 /etc/apt/auth.conf.d
202835524      0 drwxr-xr-x   2 root     root            6 Apr  8 10:22 /etc/apt/keyrings
  1467146      0 drwxr-xr-x   2 root     root            6 Apr  8 10:22 /etc/apt/preferences.d
 68562845      0 drwxr-xr-x   2 root     root            6 Apr  8 10:22 /etc/apt/sources.list.d
135370943      0 drwxr-xr-x   2 root     root           84 Apr 28 12:04 /etc/apt/trusted.gpg.d
Going to keep looking.
muru
  • 207,228
I indeed also encountered this issue, but noticed apt-get is working when starting the container with the option --privileged. It looks like the issue is due to a failing keyring. apt-ket list is also not working without running with the --privileged option. However, docker build does not support this option, so I also had to switched to proposed method on: https://docs.docker.com/engine/install/centos
