I'm using an Asus ROG Strix system, and I've been dual-booting Windows and Linux for a couple of months now with no issue. A few days ago, I decided to upgrade my system to Windows 11. After the update, I'm stuck with a GRUB menu saying something like
GNU GRUB version 2.04...
Minimal BASH-like line editing is supported. For the first word, TAB lists possible command completions.
Anywhere else TAB lists possible device or file completions.
grub>
I've checked a couple of other questions online like this and most were recommended booting using a live USB stick and fixing the bootloader using the boot-repair package. I installed the package but I don't have the option most people see and recommend. The recommended repair option. This is the pastebin from creating the BootInfo summary option. Not sure where to go from here. Wondering how I can repair the bootloader to what it was before.
I am also unable to even go past the first step in this tutorial, as I always get an error mount: /mnt: wrong fs type, bad option, bad superblock on /dev/sdb5, missing codepage or helper program, or other error. Looking further into this, I tried to fix the bad drive using fsck as outline here but then I get this error.
fsck from util-linux 2.34
e2fsck 1.45.5 (07-Jan-2020)
ext2fs_open2: Bad magic number in super-block
fsck.ext2: Superblock invalid, trying backup blocks...
fsck.ext2: Bad magic number in super-block while trying to open /dev/sdb5
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
Also, any of the recommended commands give the same error as well. Running the sudo fdisk -l command, and I get this on my main drive with /dev/sdb5 being my Ubuntu partition
Disk /dev/sdb: 256.18 GiB, 275064201216 bytes, 537234768 sectors
Disk model: Crucial_CT275MX3
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: EF9C52D6-8EB4-46F7-89FA-4AEA30C7089D
Device Start End Sectors Size Type
/dev/sdb1 2048 1085439 1083392 529M Windows recovery environment
/dev/sdb2 1085440 1290239 204800 100M EFI System
/dev/sdb3 1290240 1323007 32768 16M Microsoft reserved
/dev/sdb4 1323008 319723994 318400987 151.8G Microsoft basic data
/dev/sdb5 321163264 537233407 216070144 103G Linux filesystem
Not sure it matters, but I eventually downgraded back to Windows 10 from 11 (for personal reasons) but that obviously had no effect on the issue.
