I got this final error when I upgraded from 21.10 to 22.04 LTS:
root@reaper /opt # apt upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up grub-efi-amd64-signed (1.180+2.06-2ubuntu7) ...
mount: /var/lib/grub/esp: special device /dev/sda15 does not exist.
dpkg: error processing package grub-efi-amd64-signed (--configure):
 installed grub-efi-amd64-signed package post-installation script subprocess returned error exit status 32
dpkg: dependency problems prevent processing triggers for shim-signed:
 shim-signed depends on grub-efi-amd64-signed | grub-efi-arm64-signed; however:
  Package grub-efi-amd64-signed is not configured yet.
  Package grub-efi-arm64-signed is not installed.
dpkg: error processing package shim-signed (--configure): dependency problems - leaving triggers unprocessed Errors were encountered while processing: grub-efi-amd64-signed shim-signed needrestart is being skipped since dpkg has failed E: Sub-process /usr/bin/dpkg returned an error code (1)
If someone could point me in the right direction, I would be very grateful as its bugging me at the moment.
Thanks, Salvo
salvo
  • 321
I managed to resolve it by running: apt remove shim-signed grub-efi-amd64-bin --allow-remove-essential
There was no EFI system on the server, confirmed by fdisk -l
salvo
  • 321
