I get the below errors when I hit sudo apt upgrade. I am unable to fix the error. Any help, please?
root@Ubuntu-2204-jammy-amd64-base ~ # sudo apt upgrade -y
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
Try Ubuntu Pro beta with a free personal subscription on up to 5 machines.
Learn more at https://ubuntu.com/pro
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up grub-efi-amd64-signed (1.182~22.04.1+2.06-2ubuntu10) ...
mount: /var/lib/grub/esp: special device /dev/sda15 does not exist.
dpkg: error processing package grub-efi-amd64-signed (--configure):
installed grub-efi-amd64-signed package post-installation script subprocess returned error exit status 32
dpkg: dependency problems prevent processing triggers for shim-signed:
shim-signed depends on grub-efi-amd64-signed | grub-efi-arm64-signed; however:
Package grub-efi-amd64-signed is not configured yet.
Package grub-efi-arm64-signed is not installed.
dpkg: error processing package shim-signed (--configure):
dependency problems - leaving triggers unprocessed
shim-signed
needrestart is being skipped since dpkg has failed
