When I install flashplugin i have problem :
flashplugin-installer: downloading http://archive.canonical.com/pool/partner/a/adobe-flashplugin/adobe-flashplugin_11.2.202.235.orig.tar.gz
Traceback (most recent call last):
  File "/usr/lib/update-notifier/package-data-downloader", line 234, in process_download_requests
    dest_file = urllib.urlretrieve(files[i])[0]
  File "/usr/lib/python2.7/urllib.py", line 93, in urlretrieve
    return _urlopener.retrieve(url, filename, reporthook, data)
  File "/usr/lib/python2.7/urllib.py", line 239, in retrieve
    fp = self.open(url, data)
  File "/usr/lib/python2.7/urllib.py", line 207, in open
    return getattr(self, name)(url)
  File "/usr/lib/python2.7/urllib.py", line 344, in open_http
    h.endheaders(data)
  File "/usr/lib/python2.7/httplib.py", line 954, in endheaders
    self._send_output(message_body)
  File "/usr/lib/python2.7/httplib.py", line 814, in _send_output
    self.send(msg)
  File "/usr/lib/python2.7/httplib.py", line 776, in send
    self.connect()
  File "/usr/lib/python2.7/httplib.py", line 757, in connect
    self.timeout, self.source_address)
  File "/usr/lib/python2.7/socket.py", line 571, in create_connection
    raise err
IOError: [Errno socket error] [Errno 113] No route to host
ttf-mscorefonts-installer: downloading http://downloads.sourceforge.net/corefonts/andale32.exe
    h.endheaders(data)
    self.send(msg)
    self.connect()
    raise err
Konfigurowanie flashplugin-installer (11.2.202.235ubuntu0.12.04.1) ...
Jorge Castro
  • 73,717
Mcgr3g0r
  • 27
I have the same problem with the installation of flashplugin-installer in Ubuntu 12.04. I have fixed this bug by:
  1. Adding the correct proxy in /etc/environment and /etc/wgetrc
  2. Adding the following line in /etc/sudoers:
    • Defaults env_keep="http_proxy"
  3. By installing the following:
    • sudo apt-get install policykit-1
    • sudo apt-get install ttf-mscorefonts-installer
    • sudo apt-get --reinstall install flashplugin-installer
And now the problem is solved.
"No route to host" is a network connectivity problem.
Do you have an otherwise working internet connection?
You may want to check:
  • Can you ping either host (archive.canonical.com or downloads.sourceforge.net) from the same PC?
  • Do you have any firewall or other network setup that could be blocking access to these sites?
  • Do you rely on a proxy server to access the web that you may have configured in your browser and in APT, but that Python/update-notifier is not picking up? If so, this bug report may be helpful in 12.04. Essentially the problem is that the installer for these two packages require access to the web to download data, but sudo is not passing them your system proxy settings (APT gets it proxy settings a different way so is unaffected).
thomasrutter
  • 37,804
