-1
My old display died and was replaced with a Philips 28" 288E2 model, capable of 3840x2160 resolution (aka 4K). A laptop has integrated Intel UHD Graphics (v2.0). The display is detected when plugged in via HDMI to the laptop and the full resolution is available and selected as the secondary display. This under Xubuntu 21.10 Everything works as expected, in other words.
A desktop machine is fitted with a Nvidia GTX1060 3GB card. Using exactly the same display and HDMI cable the highest resolution detected is 1920x1080. This is with the Nouveau driver and both 21.10 and, now, 22.04 LTS.
I have forced lightdm into 3840x2160 mode by following the recipe given in Wrong Login Screen Resolution so I have a graphics workaround for the time being. However, it seems to me that the Nouveau driver should be able to pick up the GPU's capability.
What I really want to do is to run CUDA on the desktop system. The Nvidia driver modules (I have tried several, including the currently recommended 510 version, on both 21.10 and 22.04LTS) are not loaded by the kernel at boot time. I have tried adding pci=realloc to /boot/grub/grub.cfg but that made no difference. Consequently I don't have a usable display and need to ssh in from another machine to roll back to the Nouveau solution.
Can anyone suggest what I can do to get the Nvidia driver working, and hence enable CUDA?
Thanks, Paul
I am now convinced that this is a hardware incompatibility arising from trying to connect the Nvidia 1060 to the Philips 288E2 over HDMI. The card doesn't have a DP output and the monitor doesn't have DVI-D so I am stuck with what I have - 4k display with the Nouveau driver.
A fresh install of Ubuntu with UEFI boot brought a lot of grief and no solution. Oh well.
My thanks to ChanganAuto for patient assistance.
