I’ve tried using multiple monitors to install ubuntu server, i was able to boot it and i reached a screen saying test/install ubuntu server. After pressing enter some lines showed up and errors messages like “The current input timing is not supported by the monitor display.Please change your input timing to 1366x768@60Hz or any other monitor listed timing as per the monitor specifications “ on a dell monitor and “not optimum mode” on Samsung monitors.I don’t know how to proceed.please help
I had same problem (although the message had a different resolution). I needed to install Ubuntu 22.04 from USB to a Dell PowerEdge T550 Server and it only has a VGA port. When I selected "Ubuntu" from the boot menu, I would not see the welcome screen, but would get an error message from the monitor about the resolution.
I finally tried the second selection in the list "Ubuntu (safe graphics)" and I got the Welcome Screen inviting me to "Try" or "Install". I am able to install, but on the reboot I got the same error about the monitor resolution. I found that the grub option nomodeset is the same as "Safe Graphics".
It's a bit tricky, because you need to update /etc/default/grub and then run upgrade-grub on the installed system (update-grub will generate a new /boot/grub/grub.cfg file).
Here's how I did it:
  1. Install Ubuntu 22.04 using "Ubuntu (Safe Graphics)" option
  2. Boot from a live USB (similar to "Install" but instead select "Try").
  3. Once it boots, open a terminal (Ctrl+Alt+T) and mount your Ubuntu partition on /mnt. I’m assuming the Ubuntu partition is /dev/sda2, but you should determine this yourself. (If you go on the file manager and select "Other Locations" it will show you the hard drive is /dev/sdaX):
sudo mount /dev/sda2 /mnt
  1. Edit /mnt/etc/default/grub Modify GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" so that it reads:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset"
  1. Mount dependencies:
sudo mount --bind /dev /mnt/dev
sudo mount --bind /proc /mnt/proc
sudo mount --bind /sys /mnt/sys
sudo mount --bind /dev/pts /mnt/dev/pts
sudo cp /etc/resolv.conf /mnt/etc/resolv.conf
  1. Change the root from the USB to the HDD:
sudo chroot /mnt
  1. Update the grub configuration:
sudo update-grub
  1. Reboot
References:
