23
After installing vpnc, network-manager-vpnc and network-manager-vpnc-gnome, the "Cisco Compatible VPN (vpnc)" option appears on the "Add VPN" menu in network manager as intended. The problem I'm having is that, despite having filled all necessary fields (so, gateway, user/group name/password), the "Add" button stays greyed out. It does seem to be a bug, since if I fill the gateway and the user name fields, the button will go green if I type only one character in the group name field (it doesn't save, however).
CLSA
  • 333
The form validation seems buggy and there is a required field ("interface name") which was not required before. It is in the "Advanced" window.
There is a GUI workaround. Instead of editing the connection with the main Gnome Settings application, you have to do the following:
  1. Launch Advanced Network Configuration (or run nm-connection-editor from terminal)
  2. Click the "+" (Add a new connection), choose "Cisco Compatible VPN (vpnc)", click "Create..."
  3. Fill all the fields
  4. Click the "Advanced..." button
  5. Fill "Tunnel interface name" with tun0
  6. Click "Apply"
  7. The Save button will still be disabled. Click "Advanced..." again and "Apply", or try ticking "Use hybrid authentication" and then tick it again.
  8. Finally, you will be able to "Save"!
This is tested on Ubuntu 22.04, Lubuntu 22.04, Pop!_OS 22.04, all with network-manager-vpnc-gnome version 1.2.8-2.
Bug reports on this issue already open in each project:
daltux
  • 575
To temporarily work around this issue, I am using the command line approach for now by connecting to the VPN I need through the vpnc command.
I followed the instructions from Using vpnc as a Command Line VPN Client, so basically this is what I did (as root user):
  • I copied /etc/vpnc/default.conf to /etc/vpnc/myvpn.conf
  • I filled /etc/vpnc/myvpn.conf with the details of my VPN:
IPSec gateway mygateway
IPSec ID mygroupid
IPSec secret mygrouppassword
IKE Authmode psk
Xauth username myuser
Xauth password mypass
  • Then, as root, vpnc myvpn.conf (or as normal user: sudo vpcn myvpn.conf)
  • To disconnect vpnc-disconnect as root (or as normal user: sudo vpnc-disconnect)
It's not as handy as clicking through the UI, but at least it's working.
