Since 22.04 was released yesterday I decided to upgrade my development machine, a 10 year old hp Pavilion with AMD processor. The upgrade went OK and completed in 1.5 hours but failed to reboot and went into emergency mode. I ran boot repair and the output was put in the following paste buffer: http://paste.ubuntu.com/p/5bm8bNgY6y/
I have plenty of disk space. / is only 72% full.
Other than a complete install, which would cause as many problems as it would solve as I have over a dozen apps I would need to reinstall, I am at a loss as to what to do.
I have a dual boot system, with Windows 10 in another partition. Ubuntu is the primary OS.
Please help.
Thanks in advance.
@heynnema
fstab:
cat /mnt/etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# /boot/efi was on /dev/sda1 during installation
UUID=B444-715A /boot/efi vfat umask=0077 0 1
#/swapfile none swap sw 0 0
/bigswapfile none swap sw 0 0
#UUID=1C1679C61679A186 /media/kevin/Windows ntfs errors=remount -ro 0 1
# Ubuntu on 2 tB drive /dev/sdb8
UUID=758626aa-c2cf-4faf-a16d-79370c7d3bcb / ext4 -ro 0 1
# Windows partition on internal HDD
UUID=21BFBE168406B05D /media/kevin/Windows ntfs -ro 0 1
# / was on /dev/sda6 during installation
UUID=7425e72e-1e3e-754b-e1c1-724f00d33c98 /Ubuntu_sec ext4 -ro 0 1
#/dev/sdb3 /media/kevin/Ubuntu_data ext4 errors=remount -ro 0 1
#/dev/sdc3 /media/kevin/Windows7 ntfs errors=remount -ro 0 1
/swapfile swap swap defaults 0 0
blkid:
sudo blkid
/dev/sda1: UUID="B444-715A" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="5fb77005-5d5f-4574-a190-f0717fd137aa"
/dev/sda3: LABEL="Windows" BLOCK_SIZE="512" UUID="21BFBE168406B05D" TYPE="ntfs" PARTLABEL="WIndows_primary" PARTUUID="6e7c930c-32b3-4145-9459-33b90c964d62"
/dev/sda4: LABEL="Windows RE tools" BLOCK_SIZE="512" UUID="BE12F7A512F760B7" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="450b37ce-7747-4712-9927-69d6bb53b976"
/dev/sda5: LABEL="RECOVERY" BLOCK_SIZE="512" UUID="860E51920E517BDD" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="c789d063-9ad4-423d-9354-4f3c70558dd0"
/dev/sda6: UUID="758626aa-c2cf-4faf-a16d-79370c7d3bcb" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="Ubuntu" PARTUUID="35691675-f076-4e2f-a12d-9c2e25dd6999"
/dev/sdb1: LABEL="SYSTEM" BLOCK_SIZE="512" UUID="F49C1AE3CB6928FA" TYPE="ntfs" PARTUUID="47ba187e-01"
/dev/sdb2: LABEL="Windows10_new" BLOCK_SIZE="512" UUID="3E1562AEE8601345" TYPE="ntfs" PARTUUID="47ba187e-02"
/dev/sdb5: UUID="ba8b676d-604c-7712-c178-2fe538ff9545" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="47ba187e-05"
/dev/sdb7: UUID="214e9383-fa91-4dc8-86f8-2c46725011f8" BLOCK_SIZE="4096" TYPE="ext4" PTTYPE="dos" PARTUUID="47ba187e-07"
/dev/sdb8: LABEL="Ubuntu primary" UUID="7425e72e-1e3e-754b-e1c1-724f00d33c98" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="47ba187e-08"
/dev/sdg1: UUID="45990508-f44c-4bf4-a315-b41e0cdb5c67" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="c5adefda-01"
/dev/sdb6: UUID="e8e98bcc-c555-1bd7-0ef7-0733b525314c" TYPE="swap" PARTUUID="47ba187e-06"
/dev/loop1: TYPE="squashfs"
/dev/loop8: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/sda2: PARTLABEL="Microsoft reserved partition" PARTUUID="57cf924b-89f1-4bd3-97a8-dadd789b4762"
/dev/loop5: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
swap: (no output)
swapon -s
memory:
free -h
Total. Used. Free. Shared. Buff/cache. Available
Mem: 15Gi. 144Mi. 14Gi. 9.0 Mi. 285Mi. 14Gi
Swap: 0B. 0B. 0B
@heynnema I repaired fstab by commenting out the swap lines and changed the lines with -ro to "defaults=rw". The system now boots into 21.10 but does not want to upgrade to 22.04. It says no new releases available.
Thanks for your help.
I got the upgrade to start using: do-release-upgrade -d @heynnema Well the upgrade proceeded to the point where it said reboot at my convenience, which I did. However the system freezes on reboot. I have a screen shot, and decyphering it is above my pay grade. Now it says kernel panic: VFS: Cannot open root device "sda6" or unknown -block (0,0): error-6. The 21.10 upgrade seemed normal. Why did the upgrade to 22.04 fail? I have a screenshot, which is a .HEIC image, but cannot attach.
Output from ls -al /boot, from previous kernel, which is 22.04:
ls -al /boot
total 222164
drwxr-xr-x 5 root root 4096 Apr 23 18:58 .
drwxr-xr-x 23 root root 4096 Apr 22 14:40 ..
-rw-r--r-- 1 root root 257253 Mar 29 10:09 config-5.13.0-40-generic
-rw-r--r-- 1 root root 260489 Mar 30 11:28 config-5.15.0-25-generic
-rw-r--r-- 1 root root 237975 Apr 8 04:44 config-5.4.0-109-generic
drwx------ 5 root root 4096 Dec 31 1969 efi
drwxr-xr-x 4 root root 4096 Apr 23 18:57 grub
drwxr-xr-x 5 root root 4096 Apr 22 15:28 grub.bak
lrwxrwxrwx 1 root root 28 Apr 22 15:01 initrd.img -> initrd.img-5.13.0-40-generic
-rw-r--r-- 1 root root 97563363 Apr 23 18:58 initrd.img-5.13.0-40-generic
-rw-r--r-- 1 root root 76596883 Apr 23 18:58 initrd.img-5.4.0-109-generic
lrwxrwxrwx 1 root root 28 Apr 22 15:01 initrd.img.old -> initrd.img-5.4.0-109-generic
-rw-r--r-- 1 root root 182800 Feb 6 15:35 memtest86+.bin
-rw-r--r-- 1 root root 184476 Feb 6 15:35 memtest86+.elf
-rw-r--r-- 1 root root 184980 Feb 6 15:35 memtest86+_multiboot.bin
-rw------- 1 root root 5976259 Mar 29 10:09 System.map-5.13.0-40-generic
-rw------- 1 root root 6246119 Mar 30 11:28 System.map-5.15.0-25-generic
-rw------- 1 root root 4759493 Apr 8 04:44 System.map-5.4.0-109-generic
lrwxrwxrwx 1 root root 25 Apr 22 15:01 vmlinuz -> vmlinuz-5.13.0-40-generic
-rw------- 1 root root 10246688 Mar 29 10:13 vmlinuz-5.13.0-40-generic
-rw------- 1 root root 11073600 Mar 30 11:29 vmlinuz-5.15.0-25-generic
-rw------- 1 root root 13668608 Apr 8 04:45 vmlinuz-5.4.0-109-generic
lrwxrwxrwx 1 root root 25 Apr 22 15:01 vmlinuz.old -> vmlinuz-5.4.0-109-generic
lsb_release -r Release: 22.04
Perhaps I should edit grub and move this line upwards. This was kernel 5.15.0.25
Latest@ 9:45 pm EDT:
ls -al /boot
total 324984
drwxr-xr-x 5 root root 4096 Apr 23 20:25 .
lrwxrwxrwx 1 root root 28 Apr 23 20:25 initrd.img -> initrd.img-5.15.0-25-generic
-rw-r--r-- 1 root root 105285205 Apr 23 20:20 initrd.img-5.15.0-25-generic
June 27 2022: The problem has bitten again when upgrading my primary computer from 20.04 to 21.04, the first step in the process of upgrading to 22.04 LTS. This time I can't even get into emergency mode. I just get a grub prompt. I think I saw a panic message during the upgrade and something to the effect that /dev/sda4, the primary Ubuntu partition, is corrupted. I can begin to list the contents of /etc/fstab and the output of lsblk, plus the other things you asked last time for me to do. I ran boot repair twice but that didn't fix the boot problem. Here is the Boot Info for the two iterations: paste.ubuntu.com/p/JQfwPJkZvJ paste.ubuntu.com/p/gWPD9GrTZp I will try to study them but I really don't know enough to make complete sense of them. Thanks for your help in advance. Last time you said to edit the question but I can't see that option available now.
I just tried to fix /dev/sda4 as follows:
sudo grub-install /dev/sda4 --efi-directory=/boot/efi --target=x86_64-efi
Installing for x86_64-efi platform.
grub-install: error: failed to get canonical path of /boot/efi'. ubuntu@ubuntu:~$ sudo grub-install /dev/sda4 Installing for i386-pc platform. grub-install: error: failed to get canonical path of /cow'.
sudo fdisk -l:
Disk /dev/sda: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: WDC WD20EZAZ-00G
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 269D15EA-10B9-4A5E-9C29-75C578F72C80
Device Start End Sectors Size Type /dev/sda1 2048 34815 32768 16M Microsoft reserved /dev/sda2 104448 1128447 1024000 500M EFI System /dev/sda3 1128448 977690947 976562500 465.7G Microsoft basic data /dev/sda4 977692672 1954252799 976560128 465.7G Linux filesystem /dev/sda5 1954252800 3797503999 1843251200 878.9G Linux filesystem /dev/sda6 3797504000 3899903999 102400000 48.8G Linux swap
sudo grub-install --root-directory=/mnt/ /dev/sda Installing for i386-pc platform. grub-install: warning: this GPT partition label contains no BIOS Boot Partition; embedding won't be possible. grub-install: warning: Embedding is not possible. GRUB can only be installed in this setup by using blocklists. However, blocklists are UNRELIABLE and their use is discouraged.. grub-install: error: will not proceed with blocklists.
I will now try to see if I can boot into recovery mode. It won't get to the grub menu, just the grub prompt, so I determined the root device and set it with root=(hd3,4), then linux=/boot/vmlinuz-5.13.52 and initrd /boot/initrd.img-5.13.52 and then "boot", but it said, after a while "root filesystem not specified" and hangs in initramfs. I repeated the latter but added "root=/dev/sda4 ro" in the linux command. This time it booted, but into emergency mode.
I had a look at the journalctl -xb log and it seemed there were errors on sdc disk ( my external backup) but no errors I noticed on sda.
