I have experienced a similar, but not quite the same problem as this question:
Failed to reboot after upgrade from 20.04 to 22.04
while upgrading from 20.04 to 21.04 yesterday, as the first step before going to 22.04. I ran a perfectly normal upgrade but grub seem to be corrupted and boot repair was unable to fix the problem in 3 iterations. I have pasted its output in the previous question.
I have also tried to boot from the grub menu but just precipitated an exit to emergency mode. At this point I'm stuck. I'm tempted to try a fresh install of 22.04 over the 20.04 installation but am afraid of losing my copious data and apps. I have edited the aforementioned question and added more information.
Here is some more data:
sudo df -k /mnt
Filesystem     1K-blocks      Used Available Use% Mounted on
/dev/sda4      479566512 383311188  71824940  85% /mnt
ubuntu@ubuntu:~$ sudo fdisk -l
Disk /dev/sda: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors Disk model: WDC WD20EZAZ-00G Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 269D15EA-10B9-4A5E-9C29-75C578F72C80
Device Start End Sectors Size Type /dev/sda1 2048 34815 32768 16M Microsoft reserved
/dev/sda2 104448 1128447 1024000 500M EFI System
/dev/sda3 1128448 977690947 976562500 465.7G Microsoft basic data
/dev/sda4 977692672 1954252799 976560128 465.7G Linux filesystem
/dev/sda5 1954252800 3797503999 1843251200 878.9G Linux filesystem
/dev/sda6 3797504000 3899903999 102400000 48.8G Linux swap
Disk /dev/sdb: 1.82 TiB, 2000398933504 bytes, 3907029167 sectors Disk model: Ultra Slim MT
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: dos Disk identifier: 0xa0f8cd62
Device Boot Start End Sectors Size Id Type /dev/sdb1 34816 921632767 921597952 439.5G 7 HPFS/NTFS/exFAT
/dev/sdb2 * 1433632768 3319283711 1885650944 899.1G 83 Linux
Disk /dev/sde: 931.51 GiB, 1000202043392 bytes, 1953519616 sectors Disk model: Ext HDD 1021
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x00261ddd
Device Boot Start End Sectors Size Id Type /dev/sde1 63 204796619 204796557 97.7G 7 HPFS/NTFS/exFAT
dev/sde2 * 204796620 723010251 518213632 247.1G 83 Linux
/dev/sde3 723011584 1235009535 511997952 244.1G 7 HPFS/NTFS/exFAT
/dev/sde4 1235011582 1953517567 718505986 342.6G 5 Extended
/dev/sde5 1235011584 1644611583 409600000 195.3G 7 HPFS/NTFS/exFAT
/dev/sde6 1644613632 1953517567 308903936 147.3G 83 Linux
ubuntu@ubuntu:~$
cat /mnt/etc/fstab
/etc/fstab: static file system information.
Use 'blkid' to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/sda4 during installation
UUID=1a961ca5-8682-433c-801d-8295ac7b88d8 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/sda2 during installation
UUID=F0AB-BFAE /boot/efi vfat umask=0077 0 1
/home was on /dev/sda5 during installation
UUID=e419774b-3520-424d-82ce-5ebc320af6a9 /home ext4 defaults 0 2
swap was on /dev/sda6 during installation
UUID=3e565a6f-c534-4709-8a72-f387666832ee none swap sw 0 0 UUID=1C1679C61679A186 /media/kevin/Seagate_Backup_Plus_Drive ntfs auto,errors=remount-ro 0 1 #UUID=1C1679C61679A186 /media/kevin/Seagate\137Backup\137Plus\137Drive ntfs errors=remount-ro 0 1 #UUID=3da2eec5-4d9c-442f-b90b-5192a1f3fe40 LABEL="Ubuntu data" /media/kevin/Ubuntu\040data ext4 errors=remount-ro 0 1 UUID=3da2eec5-4d9c-442f-b90b-5192a1f3fe40 /media/kevin/Ubuntu\040data ext4 auto,errors=remount-ro 0 1 #/dev/sdc3 /media/kevin/Windows7 ntfs errors=remount -ro 0 1 #/dev/sdc5 /media/kevin/Pictures_backup ntfs errors=remount -ro 0 1 UUID=16F40E1CF40DFEAD /media/kevin/Windows_ultra ntfs auto,errors=remount-ro 0 1 UUID=1783603b-08f2-4763-ab03-bd8e3bb65d6e /media/kevin/Ubuntu_2nd_back ext4 auto,errors=remount-rw 0 1
UUID=32AC0BF47435BEA0 /media/kevin/Pictures_backup ntfs errors=remount-ro 0 1
blkid /dev/sda4 /dev/sda4: UUID="1a961ca5-8682-433c-801d-8295ac7b88d8" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="5b763976-d826-4894-9583-d611fa20c1fb"
guiverc
  • 33,561
user78290
  • 155
follow this question to get an idea how to resolve your problem Failed to reboot after upgrade from 20.04 to 22.04
what shows you this command (try to access terminal in recovery mode or with live usb/dvd)
ls -al /boot
in future try to install a fresh install of ubuntu 22.04 not upgrade distro version.
with live usb/dvd copy your data and reinstall
Alexif_47
  • 557
