I have an Acer Aspire One netbook and I want run Linux on it, but I don't know which distribution I should choose. It has a 1.66 GHz Intel Atom processor and about 1 GB RAM, so it shouldn't be too heavy.
I have an Acer Aspire One D257 and have a couple problems, there is a small pause that I only notice when programming [0] and the sound has stopped working in 12.04, but other then that I think Ubuntu is fine, if a little slower than on a full blown Desktop computer or laptop.
If speed is important to you you might want to consider Xfce or Xubuntu which uses Xfce instead of Gnome or Unity by default.
- 924
After trying a number of distros, I have finally settled on LXLE, based on Lubuntu, to run on my Acer Aspire One 722. It works really well if you do this:
Set boot order (F2 on boot) with NETWORK boot as first option, USB HDD second and internal HDD third.
Boot LXLE from a usb stick use unetbootin to install the ISO in Linux, or Yumi or similar in Windows)
Link to your wi-fi and make sure the mouse cursor moves - try moving it around for a minute or so - if it freezes, you need to connect a wired network and re-boot.
Start the installation process once you have it booted from live usb.
Use the 'advanced' option with gparted to partition your disk, if you are starting from scratch. I set up 4 partitions as follows:
- a boot partition of 250Mb
- a root partition of 25Gb
- a swap partition (at the end) of 8Gb
- a home partition of the rest (about 260Gb)
Finish the install and re-boot, using the ethernet connection if you had a frozen cursor earlier.
Go top this page and follow the instructions for power management http://ubuntuforums.org/showthread.php?t=1811178 and the rest is useful too.
If you have any sound problems, go here - http://bernaerts.dyndns.org/linux/74-ubuntu/202-ubuntu-acer-ao722
Welcome to a fast and easy to use netbook!
- 21
- 3
I've been using an Acer AO722 for nearly two years, and I have tested lots of distros. Here are some findings:
- avoid any distro with KDE, for they overload the system. CPU temperature gets very high!
- Unity and Gnome are Ok, everything works fine (as long as you fix the boot order - see above answers), but they consume too much memory.
- XFCE distros work fine, too, with very low memory consume. I've been using Xubuntu 12.4 for more than a year, and it's on top of my GRUB order! The problem with the XFCE distros is the sound issue(s). I've managed to fix it, but I can't remember how (sorry)! It has to do with some lines in the Configuration Editor.
- LXDE distros have no sound at all, and i couldn't find a way to fix it (I've tryed Lubuntu and Peppermint).
- Bodhi Linux is great and works fine, after configuring the workspace.
- Puppy Linux Slako is another great distro. Everything working fine, but wireless configuration can be tricky.
My final choices are Xubuntu and Linux Mint.
- 11
