18
I'm using Ubuntu and every couple minutes it goes unresponsive for a half second to a full second, which isn't normally a problem but makes trying to code extremely frustrating when your trying to hit backspace or navigate the code and nothing is happening. The problem is, the freezes are so brief that top doesn't have time to show me what is spiking the CPU (assuming something is, but I don't know what else could cause this).
Does anyone know how to troubleshoot this performance issue?
Edit: I've tried login in with Gnome Classic (No Effects) instead of Unity but it still freezes up every once in awhile.
Edit: The CPU graph doesn't seem to be showing any actual spikes so it seems you were right and my original diagnosis of CPU spikes being the problem was incorrect, I now suspect IO wait. I don't recall this happening for the brief few weeks I had Windows 7 Starter running on it though, which leads me to believe it isn't (just?) the hardware.. is there anything I can tweak to improve this? I'm using an Acer Aspire One D257, with Ubuntu 11.10.
Edit: Output of dmesg is at http://paste.ubuntu.com/1060054/ and kern.log is at http://paste.ubuntu.com/1060055/
Braiam
  • 69,112
There are two additional tools that you may want to check out:
If you don't get what you want from those two tools, then you may need to use developer-tools like OProfile or Sysprof.
All the tools listed are available from ubuntu repositories
Regarding your observation with usb, from what I've heard, some usb-controllers behave a bit flaky with certain hardware which can cause Interrupt-storms, this could cause what you are describing. Try searching for usb interrupt storm and you will get quite a few hits.
Gerard Roche
  • 1,477
danjo133
  • 311
I used htop for years and I finally found how to get Cpu Utilization by numbers and percentages, I am surprised I have missed this.
htop iowait image
Press F2
Arrow to "Available meters"
Highlight CPU average
F5 or F6 to add to column
Arrow to the item "CPU [Bar]"
Press F4 till you get "CPU [Text]"
You can also get IORates
F2->Columns->Available
Add IO_RATE, IO_READ_RATE, IO_WRITE_RATE
Atherion
  • 151
The best way to see this is to use a command-line application like top or htop Install htop.
top
top
htop
htop
You would need to be watching it for a while though until you see what causes the spike (if it is indeed a spike in CPU usage and not in i/o wait, which may not be caught in all cases).
RolandiXor
  • 51,797
A new and very helpful tool is cpustat It has a graphical interface that allows you to monitor multiple pids over time.
RickyA
  • 121
