I don't see this exact question in the prompted similar questions, so if it has been asked in a different form before, please forgive me.
I currently have 20.04 on my HDD and plan to upgrade to 22.04 (installed to an NVMe SSD) when it is released. I would like to dual-boot for a little while so I can test and make sure the new setup works as I want it to, then I will switch over fully to the 22.04 on SSD and drop the dual-boot. Can anyone suggest the best way to handle this?
Thanks!
EDITED TO ADD: From some of the comments, I realize that I did not make clear enough that my question is not about the testing phase as much as it is about the migrating from HDD to SSD boot drives with a dual-boot phase in between.
I'm still looking to see if there is a clear answer to the question of where GRUB should live during the dual-boot phase: should I put GRUB on the SSD when I install 22.04 or wait to move it there when I remove the HDD?
grub can be installed on either of the two drives, and there's no point in moving grub to a different drive if it's not necessary to relocate it. During the dual boot phase you can leave grub where it is, and then reinstall grub after you remove the HDD.
karel
  • 122,292
  • 133
  • 301
  • 332
