This seems to be a very common problem. I have tried everything mentioned in the threads online, but nothing has worked.
I have an HP Chromebook 13 G1, and am running Ubuntu 20.04 and my output for uname -srm is Linux 5.13.0-39-generic x86_64.
I installed Ubuntu on the Chromebook by using MrChromebox, I'm not sure if that make a difference to anything. I know for sure the sound worked originally when ChromeOS was installed.
Here are some audio related outputs:
$ lspci -nnk | grep -A2 Audio
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Sunrise Point-LP HD Audio [8086:9d70] (rev 21)
DeviceName: Multimedia audio controller
Kernel driver in use: snd_soc_skl
$ aplay -l
aplay: device_list:276: no soundcards found...
$ pacmd list cars |egrep -i "output|active"
argument: <sink_name=auto_null sink_properties='device.description="Dummy Output"'>
device.description = "Dummy Output"
device.description = "Monitor of Dummy Output"
0 source output(s) available.
$ lspci -v | grep -i audio
00:1f.3 Multimedia audio controller: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
I have followed the steps people suggest, but I'm not sure I'm following it correctly. For example, when people suggest to add options snd-hda-intel dmic_detect=0 to /etc/modprobe.d/alsa-base.conf, I am meant to replace snd-hda-intel with snd_soc_skl right?
If anyone can give me some guidance on this, that would be wonderful.
EDIT:
The outputs I listed above were for a clean install of Ubuntu. After I change /etc/modprobe.d/alsa-base.conf to add the lines
options snd-hda-intel model=auto
and I also added blacklist snd_soc_skl to /etc/modprobe.d/blacklist.conf
Now my outputs are like this:
Kernel driver in use: snd_hda_intel
$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
active profile: <off>
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
1 source output(s) available.
module-stream-restore.id = "source-output-by-application-id:org.gnome.VolumeControl"
