Oddly enough I couldn't seem to find anything about this. Baffles me, except I'm an Ubuntu noob (switched over about 6 months ago, and absolutely loving it).
I'm simply trying to install php 7.2.31 (the version my hosting is using) on Ubuntu 20.04. I found an answer on SE for installing 7.2, but this installed 7.2.34...doh! It would be of great help if I could get a generalized answer here, something to point me in the right direction of installing any version of anything on Ubuntu (or anything:). Thanks hahaha! :)
Cinder
There have been multiple CVEs fixed in subsequent versions since 7.2.31, all the way up to 7.3.34.
You're probably not going to find a vulnerable version to install unless you download it from php directly or build it from source although, not sure you would want to do that just to run a vulnerable version. Also, I'm not sure if vulnerable versions are even available directly from php.
CVE-2020-7070
CVE-2020-7069
CVE-2020-7068
Version 7.2.34
01 Oct 2020
Core:
Fixed bug #79699 (PHP parses encoded cookie names so malicious `__Host-` cookies can be sent). (CVE-2020-7070)
OpenSSL:
Fixed bug #79601 (Wrong ciphertext/tag in AES-CCM encryption for a 12 bytes IV). (CVE-2020-7069)
Version 7.2.33 06 Aug 2020 Core: Fixed bug #79877 (getimagesize function silently truncates after a null byte) (cmb) Phar: Fixed bug #79797 (Use of freed hash key in the phar_parse_zipfile function). (CVE-2020-7068)
Version 7.2.32 09 Jul 2020 Windows: Rebuild of official Windows binaries with patched libcurl. No PHP source changes.
mchid
  • 44,904
  • 102
  • 162
