I added ondrej PPA. And tried install php 7.2, but looks like PPA has not been updated yet. What are my workarounds?
Asked
Active
Viewed 8.7k times
46
Follow the steps described below:
Add the PPA maintained by Ondrej SurĂ½:
sudo add-apt-repository ppa:ondrej/phpInstall PHP version 7.2:
sudo apt install php7.2Select the standard version of PHP:
sudo update-alternatives --set php /usr/bin/php7.2Disable PHP version 7.4 or the one you are using:
sudo a2dismod php7.4Enable version 7.2:
sudo a2enmod php7.2Restart the Apache server
sudo systemctl restart apache2
Hope this helps!
Jorgeee
- 305
Airon Gabriel
- 561
You could try adding the eoan/main PPA... Although, this is likely not a preferred route to follow.
$ sudo su
$ cp /etc/apt/sources.list /etc/apt/sources.list.bkp
$ echo "deb http://ppa.launchpad.net/ondrej/php/ubuntu eoan main" >> $ /etc/apt/sources.list
$ apt update
$ apt install php7.2 php-pear php7.2-gd php7.2-dev php7.2-zip php7.2-mbstring php7.2-mysql php7.2-xml php7.2-curl
$ exit
PipIWYG
- 51
Today I just realize that with lates ubuntu PPA update older PHP version is available now. So to install php7.3 or 7.2 just sudo apt update and you are ready to go!
