I would like to use keyboard buttons for left and right mouse clicks. I found this answer that describes remapping mouse buttons to keyboard keys. Can I use this method 'in reverse' to map keyboard keys to mouse buttons? E.g. F1 key = left click, F2 key = right click. I'd like the remap to apply on startup.
drydwy
You can use the remapper deamon keyd for this purpose. See this answer for installation, usage and tips.
After installation, use the config below.
[ids]
[main]
f1 = leftmouse f2 = middlemouse f3 = rightmouse
Rasmus
  • 8,655
This can be done with xdotool if you run Xorg. ydotool will also work on Wayland.
For example, to simulate a mouseclick with the left button:
xdotool click 1 # left click
or
ydotool click left
Bind these commands to a shortcut key, e.g. using "Settings" - "Keyboard" for the default Ubuntu desktop. On xorg, you can also use hotkey daemons that are independent of the desktop, like xbindkeys or sxhkd. Note, however, that these may be unreliable if you switch keyboard layouts, or when the computer wakes from a suspended state.
vanadium
  • 97,564
