I'm trying to install Java JDK per this YouTube tutorial:. I get to the part where I run sudo dpkg -i <FILENAME> and it gives me this:
(Reading database ... 185728 files and directories currently installed.)
Preparing to unpack javajava.deb ...
Unpacking jdk-17 (17.0.2-ga) over (17.0.2-ga) ...
dpkg: dependency problems prevent configuration of jdk-17:
 jdk-17 depends on libc6-i386; however:
  Package libc6-i386 is not installed.
 jdk-17 depends on libc6-x32; however:
  Package libc6-x32 is not installed.
dpkg: error processing package jdk-17 (--install): dependency problems - leaving unconfigured Errors were encountered while processing: jdk-17
I noticed I'm missing a couple of packages, so I tried running sudo apt-get install libc6:i386. That throws a similar error about dependencies on yet more packages.
I've also run sudo apt update and sudo apt upgrade.
Any help would be greatly appreciated
MDeBusk
  • 1,386
While installing java jdk i also got the same type of this problem.to fibure that read terminal error carefully. It tells,
jdk-18 depends on libc6-i386; however:
to figure this,
sudo apt --fix-broken install
After that unpack debian package again.
You need to install them together. I go through the process below.
Reproduced the error:
$ sudo dpkg -i jdk-17.0.1_linux-x64_bin.deb
(Reading database ... 181449 files and directories currently installed.) Preparing to unpack jdk-17.0.1_linux-x64_bin.deb ... Unpacking jdk-17 (17.0.1-ga) over (17.0.1-ga) ... dpkg: dependency problems prevent configuration of jdk-17: jdk-17 depends on libc6-i386; however: Package libc6-i386 is not installed. jdk-17 depends on libc6-x32; however: Package libc6-x32 is not installed.
Solution:
$ sudo apt-get install libc6-i386 libc6-x32
Reading package lists... Done Building dependency tree... Done Reading state information... Done The following package was automatically installed and is no longer required: systemd-hwe-hwdb Use 'sudo apt autoremove' to remove it. The following NEW packages will be installed: libc6-i386 libc6-x32 0 to upgrade, 2 to newly install, 0 to remove and 99 not to upgrade. 1 not fully installed or removed. Need to get 5,815 kB of archives. After this operation, 25.4 MB of additional disk space will be used. Get:1 http://au.archive.ubuntu.com/ubuntu jammy-updates/main amd64 libc6-i386 amd64 2.35-0ubuntu3.1 [2,837 kB] Get:2 http://au.archive.ubuntu.com/ubuntu jammy-updates/main amd64 libc6-x32 amd64 2.35-0ubuntu3.1 [2,978 kB] Fetched 5,815 kB in 1s (5,290 kB/s)
Selecting previously unselected package libc6-i386. (Reading database ... 181449 files and directories currently installed.) Preparing to unpack .../libc6-i386_2.35-0ubuntu3.1_amd64.deb ... Unpacking libc6-i386 (2.35-0ubuntu3.1) ... Selecting previously unselected package libc6-x32. Preparing to unpack .../libc6-x32_2.35-0ubuntu3.1_amd64.deb ... Unpacking libc6-x32 (2.35-0ubuntu3.1) ... Setting up libc6-x32 (2.35-0ubuntu3.1) ... Setting up libc6-i386 (2.35-0ubuntu3.1) ... Setting up jdk-17 (17.0.1-ga) ... Processing triggers for libc-bin (2.35-0ubuntu3.1) ...
Confirmation:
(Reading database ... 182019 files and directories currently installed.) Preparing to unpack jdk-17.0.1_linux-x64_bin.deb ... Unpacking jdk-17 (17.0.1-ga) over (17.0.1-ga) ... Setting up jdk-17 (17.0.1-ga) ...
press Alt+F2 and Enter “update-manager -cd” to go to software and security and check all the boxes like the answer to this link How to install libc6:i386 on 16.04.4 64bit?
then open the terminal, where you have downloaded the .deb file and run:
sudo apt-get update
sudo apt-get install -f
sudo dpkg -i filename.deb
This worked for me :)
Pilot6
  • 92,041
Sara
  • 51
