Possible Duplicate:
How do I install Oracle Java JDK 7?
I'm running Ubuntu 12.04
I know this has been asked many times but I just recently switched to linux and I'm having a hard time piecing everything together.
I have Oracle's JDK 7 running just fine from the command prompt but I'm not sure what the best way to install eclipse and maven are so that they will use it.
Last time I tried installing eclipse with apt-get and it ended up installing openjdk6.
How do I go about installing eclipse and maven so that they both are using oracle 7 jdk?
Thanks!
Talon876
  • 129
Pre question edit:
You need to:
I think it's a duplicate question, but you combine multiple questions into one. This violates the ask one question at a time component of the FAQ.
Post question edit:
You would need to look at the questions on installing eclipse and set your launcher to use a terminal so your .bashrc variables get applied. An alternate solution would be to set up the environment variables in .profile. A better alternative is to use update alternatives, but this too is covered in the oracle-jdk question.
It's my opinion that it's still a duplicate despite having narrowed scope.
RobotHumans
  • 30,112
Use the following command to avoid installation of default-jdk in Ubuntu 12.04 i.e openjdk6
$ sudo apt-get --no-install-recommends install eclipse
bitsbuffer
  • 1,297
  • 16
  • 15
I guess you have not set the path correctly
After installing openjdk set the path to the oracle jdk...
JAVA_HOME=/usr/local/java/jdk1.7.0_04 PATH=$PATH:$HOME/bin:$JAVA_HOME/bin JAVA_HOME=/usr/local/java/jre1.7.0_04 PATH=$PATH:$HOME/bin:$JAVA_HOME/bin export JAVA_HOME export PATH
This is taken for this link
AurA
  • 363
you can also get it from the ubuntu software centre, and you can also use openjdk6 or 7, you can easily install that with synaptic software centre (sudo apt-get install synaptic) I got eclipse running just fine.
Dr_Bunsen
  • 4,783
