I tried to get some free space on my system partition. I found a lot of installed kernels and I deleted some. I have 2 questions:
  1. I still have kernel 5.4.0.100 low latency. Shouldn't the normal update procedure using the program discover (Kubuntu) update my kernel to newer versions automatically? Or do I have to do this manually?
  2. There are some kernels or parts of them that I can't get rid of:
$ dpkg -l | grep linux-'[g|i|m|h]'
ii  binutils-x86-64-linux-gnu                     2.34-6ubuntu1.3                             amd64        GNU binary utilities, for x86-64-linux-gnu target
ii  linux-headers-5.11.0-46-generic               5.11.0-46.51~20.04.1                        amd64        Linux kernel headers for version 5.11.0 on 64 bit x86 SMP
ii  linux-headers-5.13.0-30-generic               5.13.0-30.33~20.04.1                        amd64        Linux kernel headers for version 5.13.0 on 64 bit x86 SMP
ii  linux-headers-5.4.0-100                       5.4.0-100.113                               all          Header files related to Linux kernel version 5.4.0
ii  linux-headers-5.4.0-100-lowlatency            5.4.0-100.113                               amd64        Linux kernel headers for version 5.4.0 on 64 bit x86 SMP
ii  linux-headers-lowlatency                      5.4.0.100.104                               amd64        lowlatency Linux kernel headers
ii  linux-hwe-5.11-headers-5.11.0-46              5.11.0-46.51~20.04.1                        all          Header files related to Linux kernel version 5.11.0
ii  linux-hwe-5.13-headers-5.13.0-30              5.13.0-30.33~20.04.1                        all          Header files related to Linux kernel version 5.13.0
ii  linux-image-5.4.0-100-lowlatency              5.4.0-100.113                               amd64        Signed kernel image lowlatency
ii  linux-image-lowlatency                        5.4.0.100.104                               amd64        lowlatency Linux kernel image
ii  linux-modules-5.4.0-100-lowlatency            5.4.0-100.113                               amd64        Linux kernel extra modules for version 5.4.0 on 64 bit x86 SMP
How can I delete them?
EDIT: After following Someone's answer, it seems to be all clean:
ii  linux-headers-5.13.0-30-lowlatency            5.13.0-30.33~20.04.1                        amd64        Linux kernel headers for version 5.13.0 on 64 bit x86 SMP
ii  linux-headers-lowlatency-hwe-20.04            5.13.0.30.33~20.04.17                       amd64        lowlatency Linux kernel headers
ii  linux-image-5.13.0-30-lowlatency              5.13.0-30.33~20.04.1                        amd64        Signed kernel image lowlatency
ii  linux-image-lowlatency-hwe-20.04              5.13.0.30.33~20.04.17                       amd64        lowlatency Linux kernel image
ii  linux-modules-5.13.0-30-lowlatency            5.13.0-30.33~20.04.1                        amd64        Linux kernel extra modules for version 5.13.0 on 64 bit x86 SMP
Thank you all for your help.
Error404
  • 8,278
  • 35
  • 60
sebigbos
  • 111
You are having an old and unsupported kernel ie. 5.11.0-46. Moreover, you have removed some of the packages of every kernel, but didn't remove the kernels properly; and you also don't have the latest kernel for Ubuntu 20.04 ie. 5.13.
I recommend running the following command to remove all the old and unsupported kernels:
dpkg -l | egrep "linux-(signed|modules|image|headers)" | grep -v $(uname -r | cut -d - -f 1) | awk {'print $2'} | xargs sudo apt purge -y
Then update and install the latest HWE kernel (the kernel 5.11 suggests you use the HWE stack):
sudo apt update && sudo apt install --install-recommends linux-generic-hwe-20.04 --reinstall && sudo apt upgrade -y
If you want to free up space in /boot then see How do I free up more space in /boot?
Error404
  • 8,278
  • 35
  • 60
