-2
I want to create a new OS which is based on Ubuntu. I changed everything in Ubuntu like name, screenfetch logo, etc., but I failed when it comes to creating an iso for my OS. I want to change everything like bootloader logo, bootloader name, etc. I don't want to show any Ubuntu name in that. I also want to change the grub screen. Which tools/packages do I need to install for that?
In particular I want to know which tools are generally used by Lubuntu/Xubuntu teams when they make their OS from an Ubuntu build.
Error404
  • 8,278
  • 35
  • 60
Read https://wiki.ubuntu.com/DerivativeDistroHowto
Modify the Pretty Name Variable in /usr/lib/os-release and change "Ubuntu" to the name you prefer. For changing the icon, run:
sudo cp -r /usr/share/icons/hicolor/256x256/apps/ubuntu-logo-icon.png /usr/share/icons/hicolor/256x256/apps/ubuntu-logo-icon.png.bak
And then place the logo's .png file in /usr/share/icons/hicolor/256x256/apps/ and rename the .png file to ubuntu-logo-icon.png.
I want to change everything like bootloader logo .
I assume you are talking about the boot splash screen, right? See How do I change the plymouth bootscreen? You can get one Plymouth them from Pling or create your own theme.
See How to safely change OS name in grub boot menu? You have to modify /etc/default/grub.
A.F.A.I.K, there is no such tool/package.
I presume you're talking about the Grub theme. You can select one theme from Pling or create your own theme.
They don't really use any tool, they modify the files and repositories themself.
Error404
  • 8,278
  • 35
  • 60
I'd recommend Cubic but you have to still go around and change branding, make your own DE, etc. I recommend building the desktop and server versions on Ubuntu Server with Cubic, it gets rid of those pesky DE bits scattered everywhere.
