-1
I can't seem to be able to extend a partition while having unallocated space on my drive. Firstly i tried Disks but it shows as the following: Tried Resizing Volume
It shows Free Space Following as 0.00 GB but i have nearly 77GB of free space Amount of Free Space Available but unmounted
I've also tried GParted while booting from a live USB but that also didn't work
Please Help
I am assuming that you are trying to resize partition 5, the 20 GB ext4 partition?
The partition being extended must be contiguous with (next to) the empty space. You will need to move about partitions on your disk to cause this to happen.
Since partitions 2 and 3 are apparently windows partitions, I would encourage you to use windows tools to move those partitions. It is unclear what partition 4 is, but I will assume at this time this is also a windows partition.
Charles Green
  • 21,859
Is this your / mount you're trying to extend? First check:
    # vgdisplay
This should show you the name of the volume you want to extend.
For example, let's say it is mounted as /dev/mapper/ubuntu--vg-ubuntu--lv, you could try something like this. That's how / is mounted on my server. I recently installed a 1TB M.2 SSD on my Ubuntu 20.04 LTS Server and it went from 100GB to 1TB! These commands will need to be run as root, or sudo'd as such...
    # lvextend -l +100%FREE /dev/mapper/ubuntu--vg-ubuntu--lv
# resize2fs /dev/mapper/ubuntu--vg-ubuntu--lv
coreyo
