How do I solve this sudo apt update error?
Err:9 http://download.opensuse.org/repositories/home:/pzz/xUbuntu_20.04  InRelease
  The following signatures were invalid: EXPKEYSIG 23E07629B9E3C9E4 home:pzz OBS Project <home:pzz@build.opensuse.org>
Fetched 2,441 B in 3s (819 B/s)
Reading package lists... Done
Building dependency tree
19 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://download.opensuse.org/repositories/home:/pzz/xUbuntu_20.04  InRelease: The following signatures were invalid: EXPKEYSIG 23E07629B9E3C9E4 home:pzz OBS Project <home:pzz@build.opensuse.org>
W: Failed to fetch http://download.opensuse.org/repositories/home:/pzz/xUbuntu_20.04/InRelease  The following signatures were invalid: EXPKEYSIG 23E07629B9E3C9E4 home:pzz OBS Project <home:pzz@build.opensuse.org>
W: Some index files failed to download. They have been ignored, or old ones used instead.
I have tried solutions from post How do I fix the GPG error "NO_PUBKEY"? but they did not work:
$ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 23E07629B9E3C9E4
[sudo] password for master:
Executing: /tmp/apt-key-gpghome.QYq1pmnpyE/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 23E07629B9E3C9E4
gpg: keyserver receive failed: Server indicated a failure
$ gpg --keyserver hkp://keyserver.ubuntu.com:80 --recv ^C
$ 23E07629B9E3C9E4^C
$ gpg --keyserver hkp://keyserver.ubuntu.com:80 --recv 23E07629B9E3C9E4
gpg: keyserver receive failed: No data
Sun Bear
  • 3,014
You have added some thirdparty repository to the system. For now its key is expired.
So you have to disable this repository using Software & Updates.
N0rbert
  • 103,263
Just update the expired gpg key:
curl -fsSL https://download.opensuse.org/repositories/home:pzz/xUbuntu_20.04/Release.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/home_pzz.gpg > /dev/null
source: https://software.opensuse.org/download.html?project=home%3Apzz&package=sane-airscan
My error was with Google Chrome, so I just updated it with:
wget -q -O - https://dl.google.com/linux/linux_signing_key.pub | sudo gpg --dearmor -o /usr/share/keyrings/google-chrome.gpg
Then updated with
sudo apt update
Jared
  • 361
My issue was with Amazon Corretto, so I did this:
wget -O - https://apt.corretto.aws/corretto.key | sudo gpg --dearmor -o /usr/share/keyrings/corretto-keyring.gpg
then ran:
sudo apt update
