19
I want to use a looped video clip as my webcam source in a Google+ Hangout. I installed v4l2loopback and created a video loopback device. But I haven't figured out how to write the video frames to the device. The given example is:
gst-launch videotestsrc ! v4l2sink device=/dev/video1
So after reading the manual page for gst-launch and trying to understand what was going on, I made my feeble attempt:
sudo gst-launch-0.10 filesrc location=/home/briankb/Videos/darthvaderdancing.mp4 ! v4l2sink device=/dev/video0
Which resulted in:
Setting pipeline to PAUSED ...
libv4l2: error getting pixformat: Invalid argument
Pipeline is PREROLLING ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
(gst-launch-0.10:12622): GStreamer-CRITICAL **: gst_caps_get_structure: assertion `GST_IS_CAPS (caps)' failed
New clock: GstSystemClock
(gst-launch-0.10:12622): GStreamer-CRITICAL **: gst_structure_get_name: assertion `structure != NULL' failed
Caught SIGSEGV accessing address (nil)
#0  0x00007fc1890f0b03 in poll () from /lib/x86_64-linux-gnu/libc.so.6
#1  0x00007fc18962bff6 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2  0x00007fc18962c45a in g_main_loop_run ()
#3  0x00007fc189b5c4cb in gst_bus_poll ()
#4  0x0000000000404587 in ?? ()
#5  0x0000000000403c34 in ?? ()
#6  0x00007fc18902b76d in __libc_start_main ()
#7  0x00000000004043bd in ?? ()
#8  0x00007fff88253ed8 in ?? ()
#9  0x000000000000001c in ?? ()
#10 0x0000000000000006 in ?? ()
#11 0x00007fff882548c4 in ?? ()
#12 0x00007fff882548d4 in ?? ()
#13 0x00007fff882548dc in ?? ()
#14 0x00007fff88254904 in ?? ()
#15 0x00007fff88254906 in ?? ()
#16 0x00007fff8825490f in ?? ()
#17 0x0000000000000000 in ?? ()
Spinning.  Please run 'gdb gst-launch 12622' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
The clip I'm trying to use an h264 video at 29.97 fps, 320x240, and in an mp4 container (it's from Youtube).
blee
  • 589
The gst-launch manpages tells us that we need to decode the video first, and the easiest way to do so is like this:
gst-launch-0.10 filesrc location=[location] ! decodebin ! v4l2sink device=/dev/video0
gst-launch does not need to be run as root, and [location] can be relative too!
小太郎
  • 331
Just use v4l2loopback with mplayer.
  1. Download it,
  2. compile it (make and su -c 'make install'),
  3. load the module with su -c 'modprobe v4l2loopback',
  4. then change one line in the file examples/yuv4mpeg_to_v4l2.c of the v4l2loopback source folder from
    v.fmt.pix.pixelformat = V4L2_PIX_FMT_YUV420;
    to
    v.fmt.pix.pixelformat = V4L2_PIX_FMT_YVU420;
  5. and do make in this folder.
  6. Then run it from the examples directory like this:
    mkfifo /tmp/pipe  # only needed once, as long as you do not delete the file /tmp/pipe
    ./yuv4mpeg_to_v4l2 < /tmp/pipe &
    mplayer movie.mp4 -vf scale=480:360 -vo yuv4mpeg:file=/tmp/pipe
    where you replace movie.mp4 with the name of your video file. And replace /dev/video0 with your loopback device.
MPlayer is able to play any webstreams, all kind of video files and so on. I just tested it with a file from http://www.tagesschau.de which is a german news site.
TS=$(wget 'http://www.tagesschau.de'$(wget http://www.tagesschau.de -q -O - | grep 'Letzte Sendung' | sed -e 's%.*href="%%' -e 's%".*%%') -q -O - | grep '\.webm\.webm' | sed -e 's%.*href="%%' -e 's%\.webm\.webm".*%.webm.webm%')
mplayer $TS -vf scale=480:360 -vo yuv4mpeg:file=/tmp/pipe
erik
  • 667
