When my Lenovo Yoga 7 starts, suddenly, as soon as I can see the login screen, the monitor backlight gets dark. Even when I login it stays like this and I have to manually set illumination higher. Any idea where this comes from or how to stop it? Thanks in advance.
Asked
Active
Viewed 109 times
Ok the answer was quite similar to the one mchid provided in his link.
So again, thanks for this hint.
The solution is acpi_backlight=vendor which can be done like this for example:
cd /etc/default
sudo nano grub
GRUB_CMDLINE_LINUX_DEFAULT="acpi_backlight=vendor"
sudo update-grub
reboot
The value was taken from: https://www.kernel.org/doc/Documentation/admin-guide/kernel-parameters.txt
