I've been having issues booting from a USB to reinstall windows (or any OS for that matter). I've got my BIOS set up correctly according to the Manufacturer (It's the legacy BIOS version with settings correct to ASUS BOOT FROM USB SETTINGS).
I've also attempted to boot via grub using the command lines mentioned in this other AskUbuntu stack forum (Stack Exchange - Boot USB from Grub 2) but when I follow this it says no valid efi file. I know the USB should be correct, I've tried multiple USB's multiple OS's and i've even gone as far as to try all variants of the MBR/GPT and BIOS/UEFI options in rufus despite Ubuntu command line telling me it is GPT and the bios saying it can run Shell efi (I may be confused by the BIOS UEFI difference but regardless, I've tried both to no avail.)
If I use the BIOS's override function it won't boot the USB it just goes back to the BIOS after a quick black flicker and if I change boot order in BIOS it goes to some kind of bootloop (I think it's trying to boot to GRUB when it does this but I could be wrong, in this case I have to go back to BIOS and override boot back to ubuntu)
Ubuntu was installed via USB and is the lubuntu variant although I don't think that matters unless it cocked up the GRUB installation?
Could this be a damaged GRUB installation? One thing to note (although maybe unrelated) I lost all audio output when Installing Lubuntu so something definitely doesn't communicate or is missing somewhere. Is there another way I can get the thing to boot my windows USB?
EDIT: sidenote, one of the USBs I'm using was actually made with the windows 10 usb tool on the microsoft site and also doesn't work so even if I cocked up with rufus, that one 'should' work?
Edit: Followed instructionsGrub2 Boot+Install Windows
grub>chainloader (hd0,gpt1)/efi/boot/bootia32.efi
grub>boot
error: you need to load the kernel first
