I'm having a constant battle with Bios boot options and grub... for example, I have windows 7 on a USB that i wish to install on my laptop (which has 2 HDDs, both have a Linux distro on them (ubuntu and arch), i select it on the USB on the HP Bios, which it still boots to Grub anyways... how does it do it is there any way on booting from grub to usb to install over the Arch Linux?
I made the USB using Rufus.
Thanks,
Joel
  • 52
There are different keys for entering into the boot menu for various models you can fid them here.
Vijay
  • 8,556
Try this:
Locate where the vmlinuz or vmlinuz-linux and initrd.gz or initramfs-linux.img files are located.
Insert the USB drive.
Boot the system.
Press C to get to the command-line.
Find the partitions:
grub> ls
This will show you the available devices.
(hd0) (hd0,msdos5) (hd1) (hd1,msdos0)
Use this information, along with our knowledge of where the vmlinuz or vmlinuz-linux and initrd.gz or initramfs-linux.img files are to boot the system, suppose USB drive is hd1,msdos1 /dev/sdb1, run this:
grub> linux (hd1,msdos1)/install/vmlinuz root=/dev/sdb1
grub> initrd (hd1,msdos1)/install/initrd.gz
grub> boot
kyodake
  • 17,808
This is how I was able to boot Windows 10 from USB using grub:
grub> ls
(hd0) (hd0,msdos1) ...
grub> set root=hd0,msdos1
grub> chainloader /efi/boot/bootx64.efi
grub> boot
where (hd0,msdos1) is the bootable Windows USB Stick.
Miguel
  • 103
